2018 iPad Pro
spidercyj
sry how does this work haha. Can i get it changed even if it's working fine or do i need to self-inflict damage to the screen so that it's categorised under accidental damage :o
Sent from OnePlus GM1900 using GAGT
I talked to the Apple staff before and they recommend self inflict damage because Apple don’t take in non spoilt stuff.
I never get Apple care before and now all my iPad still working
Imaginary stuff seldom spoil one
Yes plan to use long term, at least 2-3 years. So far mine has been inside the Logitech Slim Folio Pro since the day I bought it, hope won’t have any bending issues.
I also using slim folio but recently keep taking it out to read manga coz very heavy with the case on and also my Apple care + 1 year anniversary coming up
Snoweagle
Mine’s inside the case permanently. Gaming I will just fold it with the keyboard inside while reading (on the go) I just fold the keyboard to face behind. Only thing is your fingers will keep pressing onto the keys.
ragnarokprophecy
Then when you bring it in do you get a new or a refurbished one?
szeli
e magic keyboard with floating design starts at 299USD 😆🙄
Mclairs83
bought the 2018 refurbished 64gb wifi model instead.
since ipad pro 2020 is much more focus on camera and LIDAR, which i have no interest with.
might as well stick to the previous generation at a much cheaper cost.
surprisingly there are alot of people trying to sell their ipad pro 2018 same memory at a higher price with a few months left of warranty. :s22:
Glariel
Good choice. A12X and A12Z not much difference. People who have iPad Pro 2018 shouldn’t be looking to upgrade to the 2020 one.
USBThumbDrive
Not much improvement other than Camera + Lidar.
Good time to sell my 11" and upgrade to the 1TB 12.9 Same 2018, for some reason everyone is letting go of their well condition 2018 iPad
Snoweagle
Perhaps those people just want to upgrade to latest model.
LouisLoh
Refurbished set are a good buy. Would recommend getting Apple Care + so that you have worry free for at least 2 years. If possible, get the higher storage. 64GB nowadays are quite little.
Thanks, would definitely consider AC+
just wondering if the refurb unit is a good value at that pricing.
youhsueh
Definitely a better value with the launch of the new 2020 iPad Pro.
The refurbished store prices for the 2018 iPad Pro have dropped by about $200 (at least for the 11" cellular 256gb)
