2018 Macbook Pros launched
Jirachi
The upgraded processor and 32GB memory for the 2018 models should be snappier since I used PR and AE on my MBP 15 (2017).
On my 2017 model, the encoding progress bar seems to be crawling like never ending with the fans running at full blast in the background :s13:
Too bad, I bought the model few months and the next upgrade is years away :s22:
How many months exactly is that? Try to have some dealings with Apple CSO? I’ve seen some success stories on r/Apple
manofsorrows
My was a maxed out 13” 2017 version from the refurbished store. Lagi no chance for me.
Chevalier
I will be getting a 15" with applecare. It'll be my daily machine for work for network designs and installations...video editing on the side and photos.
Having a hard time deciding between the i7/16/512 vs i9/32/1tb
Will be keeping this laptop for at least 3 years..
I already have a Mac at home too...
Hope the benchmarks for the i7 vs i9 come out soon
TrueBeliever_jh
breaking:
Apple’s redesigned MacBook Pro keyboard uses new method for repelling dust, reports iFixit
A silicone membrane sits underneath the key, as described in a patent application from March
Now, iFixit says it’s uncovered something that indicates that the new MacBook Pro keyboards use a silicone membrane underneath each individual key to keep dirt and other unsavory particles from finding their way under the keyboard and locking it up. The repair organization dismantled a new 15-inch MacBook Pro keyboard to discover the new mechanism.
The Great Apple Keyboard Cover-Up
rvyne7
I tried selecting my dream specs
15" + i9 + 1tb SSD + 16gb ram (never added the gpu in equation coz im gonna use eGPU)... its wooping 5k SGD or 400 SGD monthly if its instalment... too much ey?
is moving i7 to i9 really big performance boost? is that really future proof worth it? 8 core...
I never owned laptop with i7 before its mostly i5... and previous rig so far only 1x I built with i7 never notice the difference with my type of games. mostly RTS/building simulation/MMORPG
alternative is
13" + i5 + 1tb SSD + 16gb ram ... 3.7k or 300 SGD monthly...
TrueBeliever_jh
actually that will depend on how CPU intensive your game is going to be.
i gather you are on 4k, then mostly you want 60fps. which is going to be CPU intensive.
i added mine config: 15" + 16GB = 4k
then add in the sleeve = 300 SGD
AppleCare? 500 SGD
then USB-C hub = 200 SGD
i really am not the target audience after all :(
this might also be my first i7. was on i5 all along.
chenaz
Insane price . I still prefer none touch bar model for gaming or etc
htngwilliam
I plan to get the entry $2588 model. Actually I don’t need the touchbar but again suck thumb as we all like the 8th gen intel
Parka
alternative is
If you feel like you are squeezing for time everyday, then it would be worth the upgrade. It is that simple, really.
htngwilliam
Which one more impact to upgrade? Is it cpu, ram or SSD? I am thinking storage can just buy hdd right?
