[2024] POCO PAD
Devilsire
generally yes, u can see comparison
https://www.gsmarena.com/compare.php3?idPhone1=12953&idPhone2=12237
only benefit for redmi pad pro/poco pad is 3.5mm jack and slightly larger screen
yeah thats my point, typo "is" = "isnt" in my original post
the xiaomi pad 6 was going for $303 yesterday, with free add on keyboard/case
the SD870 is also capable of gaming, a notch stronger than SD 7S Gen2 (which imho is a crippled chip)
https://nanoreview.net/en/soc-compare/qualcomm-snapdragon-870-vs-qualcomm-snapdragon-7s-gen-2
froztheart
For a budget mid level tablet..good value.
Poison is stronk. 😩
dreamcast18
Right, would be great if you come back round to update once you receive whether all's good or if there's any minor/major hiccups!
Loving it. First time taking it on a trip (reason why I bought it) as a cheap disposable workhorse.
The cross device interfacing is really good. I am now officially stick on XM ecosystem..lol
Computeron
drink whisky sia.
SGEatDrink
What are the connectivity options? Wi-Fi and/or cellular (SIM card)?
froztheart
Mine just arrived with the same setup, works great!
Shall look for the POCO Pen or compatible one to use together.
Anyways, POCO Pad is huge, similar to iPad Pro series with 12.1" screen. :s14:
dreamcast18
Yes..it's a big screen indeed. Good as an ultra portable.
chaiscool
1st usage with this vs pad 6.
Speaker sound worst, had to turn off dolby which makes it a bit better but pad 6 sounds fuller & more balance. This one sounds imbalanced - louder on bottom & harsher / hollower / thin overall.
No clear speaker option on poco but available in pad 6. It supposedly help to clear and blockage / dust etc.
Speed also can feel slower, basic app update download & install takes longer. Basic OS system patch can take like 10-15 mins. Pad 6 ddr5 & ufs3.1 vs poco ddr4 & ufs 2.2
Display color scheme don't have (original color pro) which imo make look more natural.
Hyper OS version 1.0.12 on pad 6 vs older 1.0.8 on poco.
Poco got miracast which i think mean can cast laptop to the poco. Not available on pad 6.
imo pad 6 is better if ok with smaller screen. But poco more worth it if can tahan the downgraded speaker. Bought 8/256 pad 6 with free case for $455 vs 8/256 poco no freebies for $285.
froztheart
Yup, there's downside to the POCO Pad with the price difference.
So got to weigh the pros and cons and personal usage before putting the money down.
