- Aug 8, 2012
Loving it too, convenient for mobile work and with POCO Pen, provides better ease of usage.![]()
Still going strong. Will test how it does with MSFT365 this trip.
Yes, lowest since release.It's now $275 after coupons and coins. Good price?
Nope. Get the original keyboard cover. Best!Does it comes with any case / cover when purchased?
can consider xiaomi pad 7It's now $275 after coupons and coins. Good price?
Redmi's keyboard works on POCO Pad too.Does it comes with any case / cover when purchased?
The budget differs quite a lot leh..can consider xiaomi pad 7
promo now, get free keyboard
current $359 after couponsThe budget differs quite a lot leh..![]()
Sorry, I compared with the Pro version instead which differs greatly.current $359 after coupons
personally think is worth it, cos free keyboard
Best to check with POCO Shopee directly.The reason why I asked about the free cover / case is because they indicated it on Shopee listing image
It should prompt the update without changing region though?Anyone knows how to get HyperOS 2 update?
I tried changing region to Indonesia but it's still stuck on HyperOS 1.0.10.0.UNSMIXM
Also tried update after downloading the recovery ROM and selecting the installation package also didn't work as it always failed the verification
that seems weird. reboot?I'm in Singapore region, but i'm stuck in HyperOS 1.0.10.0.UNSMIXM
When checking for new updates, it will say no new updates
If your device has nothing important/have backup (e.g. Google One backup etc.) then reset device and try liao.I'm in Singapore region, but i'm stuck in HyperOS 1.0.10.0.UNSMIXM
Should have received the update by now.
Otherwise, need visit Xiaomi Service Centre to check it out...
