blue00
- Jul 22, 2009
less than 7 years no need top up , usuaaly signs of leaking or actually is your unit need chem cleaningHome, normal servicing then they also check pressure say gas low![]()
compressor no problem usally is air con spoil because over service or no serviceVery few compressor can last 10 yrs. Mostly problem comes after 5 to 6 yrs.
Experts say healthy no need wear mask.Need or no need...listen to experts. Give and take. You build relationships long before you need help.
Bro. Many things dont breakdown overnight. They slowly..bit by bit...decline in quality. We can't tell but the experts can tell. If they spotted anything and it is still a small issue...fix it. You want to fix a small problem or fix a big problem? If dont trust this mechanic then ask for second opinion. Aircon cold so i dont believe in topping up gas sounded quite stupid actually. Many things can continue to work properly even if it declines. When it really finally breakdown..it is due to you not taking care of it when it had little symptoms.No. You will know it when you feel aircon is no longer cold
Compressor mostly has some issue after 5 yrs. Mostly. Not all.compressor no problem usally is air con spoil because over service or no service
If unnecessary top up is $90 and u unwittingly top up eg 10x , it's $900... With the unnecessary money u spent u could get a few more servicing. Anyway what relationship u need to build when there are plenty of honest contractors offering reasonable rates.Top up can earn how much? Build relationships and you wont need to get conned.
No la. Not so expensive. Top up $90???? Time to build some relationships yo lolIf unnecessary top up is $90 and u unwittingly top up eg 10x , it's $900... With the unnecessary money u spent u could get a few more servicing. Anyway what relationship u need to build when there are plenty of honest contractors offering reasonable rates.
I am all for paying slightly higher rates if it's a good contractor but I think it's stupid to pay for unnecessary services i dun need
what kind of issue?Compressor mostly has some issue after 5 yrs. Mostly. Not all.
Top up 10 times is leakage. Your examples are no good. How do you find a honest technician when you dont trust the one you are dealing with? How do you know it is a good contractor? How do you know when a service is necessary? You sound like an aircon expert to me. Maybe you can resolve your own problem and wont even need a technician ever.If unnecessary top up is $90 and u unwittingly top up eg 10x , it's $900... With the unnecessary money u spent u could get a few more servicing. Anyway what relationship u need to build when there are plenty of honest contractors offering reasonable rates.
Google bro. I not expert.what kind of issue?
Any sexpert?
Well, ts din say in his original post that the technician advised him to top up the gas. So I'm assuming he's just asking a general question or he's diy. If so, then one can only tell when aircon is no longer cold despite all the regular washing and maintenanceBro. Many things dont breakdown overnight. They slowly..bit by bit...decline in quality. We can't tell but the experts can tell. If they spotted anything and it is still a small issue...fix it. You want to fix a small problem or fix a big problem? If dont trust this mechanic then ask for second opinion. Aircon cold so i dont believe in topping up gas sounded quite stupid actually. Many things can continue to work properly even if it declines. When it really finally breakdown..it is due to you not taking care of it when it had little symptoms.
Only if it is leakingAny sexpert?
