Air purifier? - Part 2
Asakura
same as lucky. because small. easy to place around in the rooms. and cheaper to replace filters.
the green one
Lucky177
The filters, you all buy from Qoo10? Or anywhere else that i can buy? Around $35 from q10
Previously using existing Qmoney, Qpoints and coupons from events to buy.
Now think less attractive since no more MC item coupons and even if have item coupons also no longer able to stack with cart coupons. - unless now can win several $10 GC from the mamemon puzzle draws. But don't think so. Usually always kana the pathetic 20 qpoints. :s13:
Yet to buy Xiaomi filters from Taobao. :)
Jurong640
Qoo10 seems more reliable from the reviews. I just did a checked on Taobao/ezbuy, from the reviews in Chinese, it don't seem really good, somemore ezbuy got int shipping
NWT1978
I won the balls :s22::(... they should removed it and put back the cart discount coupons and the item discount coupons :s12:
Jurong640
Last time they have points where you can exchange for free shipping coupon. It was good then where you can buy those big items with expensive shipping, use the coupon to offset.
Now no more le, the memeQ idk what to do is it used for
joel3694
Hi guys,
Recently i am looking at Sharp FU-A28E. Should I get Sharp or any recommendation?
Did you managed to get your answer? I'm also looking for that around my price budget and I saw the cleanair AP 777 as well.
NWT1978
Qstamp and Qpoints
10x memeQ for 1 Qstamp or 10 Qpoint...
1 Qstamp for 3 balls as if I do not have enough balls :s22::(
Jurong640
Almost want to buy the gen 2 on qoo10. Morning at work put in cart, suppose at night to checkout. But at night it just went OOS. Sigh.
I wanted to buy a second purifier (gen2). Currently have gen 1 which bought a mth ago. Happy with gen 1, it really filters air. Fresher air.
Not sure it gen 2, i know it has lesser power. But dont know if its worth it, or just get gen 1 again
htngwilliam
Thinking of getting a Xiaomi purifier. How is it compared to Sharp AC-40E and AC-50E?
I heard the filters for both Xiaomi purifier gen 1 & 2 are interchangeable? What is the advantage of the green filter? Wonder whether Gen 2 has warranty?
kandinsky
I've had one for a few years. It's pretty okay for a starter AP, fairly compact size for the average HDB bedroom.
Jurong640
Gen 2 is not sold in Singapore, all of it are export sets. The ones u see in Qoo10, warranty is by the retailer themselves.
I think for XM air purifier is cheaper than others and useful too, can be linked with an app. My gen 1 after using for almost a month, can see and feel the difference in air quality
WussRedXLi
Samsung AX40 for $60. Used. 2015 Feb manufacture.
Get in the Taobao 300 x 300 x 25mm HEPAs at just RMB 25, cut a bit can go liao.
No need to spend much. This bugger is a true workhorse as well in addition to the Sharp. Very silent and low in power consumption as well (actually it's just 19W as measured in high speed mode with the 300 x 300 x 25mm coz more resistance so it spins slower).
Really cannot go wrong with it.
https://carousell.com/p/samsung-air...earch/products?query=samsung%20air%20purifier
Jurong640
What's the coverage of this purifier? Any knowledge? The filter expensive?
Lucky177
If want AX40 purifier, the HEPA filter get from Taobao.
No longer worth to get the "original" from Qoo10 unlike last time. Too expensive liao. The new shipping fee. :s22:
Just personal opinion.
skpuppy
