Air purifier? - Part 2
quarkz
The TB DIY frameless 300 x 300 x 25mm HEPAs (25-30rmb ea) or those customised to 285 x 320 x 45mm (rmb 110-120 ea) are ok.
The 25rmb ones would convert the AX40 into a 200 m3/hr CADR min machine, capable of handling our indon haze PM sizes (tested) and also convert the AX40 into a lower dB SPL machine in high speed accordingly.
You will lose that 320 m3/hr CADR capability though. But no issue for those using in the bedrooms, even in a 20 sqm bedroom there is enough airflow for good ACH sufficient enough for say allergic rhinitis sufferers (min of 5x ACH, after factoring in the furnitures).
If one is using the AX40 for the living room of a 4-room BTO, inclusive of the bedroom corridors and main door corridor spaces, then you'd need to use the original Samsung filters.
Either that or change to a Xiaomi Gen 3, but do remember that at 320-400m3/hr CADRs it would still be significantly louder than the AX40, even though they tested the Gen 3 @ 400 to be a wee bit better in SPL than the Gen 2 @ 330.
The main issue now is that Taobao official forwarder (Cainiao) does not really ship these DIY type HEPAs via air ship already. They are forcing you to do sea shipping, and that'd be volumetric weight if i am not wrong.
And most 3rd party forwarders are more than happy to levy half-volumetric charges for such light items, cannot run one unless you are lucky coz you are just shipping 2pcs of 300 x 300 x 25mm and so it's not so immediately apparent to the warehouse workers doing the 入库.
PS. The only issue that some are complaining is that there is a slight smell (plastic) that the TB filter media gives off. This can be solved by airing the filter in lowest fan speed mode for 48hrs before using.
But still some folks find this to be an issue, coz that means 2 "missed" nights of usage.
So those pax would rather go for the originals @ SGD 90 each currently. The originals have activated carbon as well, but then the CADR for formaldehyde (if there is such an issue in the first place) is just 50 m3/hr CADR, not very high for such granulated activated charcoal type. (the xiaomi green one is even lower than this actually).
No issue, all are personal choices
Hi WussRedXLi,
Thanks for the detailed explanation. So you tested them before using some devices? I'm thinking of getting from these 2 sources:
https://item.taobao.com/item.htm?sp...8a6463eLAg4Hx&id=522668837488&_u=t2dmg8j26111
https://item.taobao.com/item.htm?sp...8a6463eLAg4Hx&id=575355801807&_u=t2dmg8j26111
Are they ok? Thanks again!
WussRedXLi
i dont open window. i turn on aircon all the time but also need fan when i sleep. my wife scold me for the fan being too dangerous (for kid) and dusty.
what is my best option?
I guess if that's the case, just get a normal AP, and then a bladeless fan from TB or something. If you are looking at Dyson coz it has a small footprint, then the Xiaomi Gen 3 has a small footprint, and then the bladeless fans from TB.
If you can afford to splurge, then get the bladeless fan from Dyson.
WussRedXLi
Hi WussRedXLi,
Yes i have tested them with some devices. In-depth details are in the last 10 pages, during the 2019 haze period, after Sep 12th period........ Check out the thread.
The stuff that you listed are good. Just that need 3rd party forwarders, and probably half volumetric air shipping.
Just remember to air them out in low fan speed for at least a good 48hrs before using it proper. If you are ok with the slight smell, then just use them from the get go. After which there won't be much of a smell as you go by slowly leading to zero smell.
DriftKing
Hi shifu, would you have some dealers that you've bought the DIY versions before? I would like to have some cheaper DIY options to strap across my air circulator and also to cut and fit into an old Sharp purifier.
Based on the volumetric pricing for sea shipping , roughly how much more did it cost?
WussRedXLi
https://item.taobao.com/item.htm?spm=a1z09.2.0.0.4d982e8dF79Os1&id=558805128135&_u=m1u0hcib355f
I just received 2pcs of 300 x 300 x 25 yesterday via official forwarder AIR. 0.6kg including the shipping carton. I was charged actual weight for this 2pcs.
But now i think Cainiao also blocked it. Coz 99.99% of the HEPAs out there are blocked from using Air. I just managed to find this one that is still able to check out via AIR, but i guess that also triggered the system to block this last remaining few.
You can try for sea small parcel via Cainiao, not sure how much would it cost, sea is always volumetric. BTW, Cainiao sea is known (not very likely, but possible) to lose small packages if you do not buy quite a few thus making up a bigger package. eg i'd expect you to get 8pcs at least.
The dimensions for the shipping carton for 2pcs is 300x325 x 55mm exactly.
Pure Volumetric for 8pcs would be 3.57, or 4kg. LxHxD in cm then divide by 6000, gives you the kilograms.
WussRedXLi
If i am not terribly wrong, Cainiao sea small packages rate shd be 22rmb for 1st kg, 20rmb for subsequent 1kg.
The good rates of last time not so easy to find already. There are some 3rd party like 86of, princess, but they also have their own quirks and issues.
Charlie_Zhan
I've been using princess.. can ship filters using non sensitive air shipping.. first kg 26rmb, count by actual weight and reach SG about 3 working days..
nwh_sg
tks for the tip. I have never used princess before. I plan to stock up some Hepa filters for my 3 x purifiers. Looks like I got to learn how to use princess.
Charlie_Zhan
I find them most easiest to use than other 3rd party forwarders because everything for them can self service on their website.. no need for WeChat.
WussRedXLi
Maybe i should go try princess also. Currently using MRC and Comnbuy, but for my more special stuff.
Alternatively can also go via sea small parcel. I calculated, even full volumetric for 6kg can get you 13pcs of the 300 x 300 x 25 HEPAs.
For SGD 15 shipping.
Only thing is that it is slow, but if local last mile is good, is very safe and reliable.
Charlie_Zhan
can choose ninjavan for local last mile delivery logistic if you are using non sensitive air shipping.. for sensitive air only got one option which is dragonlink.. last time dragonlink is sibei jialat.. but recently I tried it again a few times and sometimes they are even faster than ninjavan.. they deliver same day upon receiving air parcel while ninjavan usually next day..
vofzxy
Xiaomi shop in guangzhou
Sent from HUAWEI VOG-L29 using GAGT
luv_boa
Saw from taobao xiaomi filter got a new green color S1. Can't find much information on it
luv_boa
How was it? Unsure if this has anti bacteria function. I think I will buy the purple filter. Just filter pm2.5 slower than green right?
