Air purifier? - Part 2
JustForInterest
Yup. Only can connect if choose china server. Just set up mine. Gen 3. So far so good. Also bgt from minihelper. Delivery is long (about 1 week plus) but ok la. Not spam. Price good.
quarkz
Hi, for those with the Samsung ax40h5000gmd purifier, where did you buy your filter? Any cheaper options? Last time I read that taobao sold compatible ones, wonder how they perform, any comment?
Thanks!
Lucky177
Profile > Setting > under Region and language > Set to Chinese mainland
I’m on iOS. Should be the similar for Android.
Are you fellows on iOS or Android? Is there only one UI location in the Mi Home app to "select China server"?
Dew36
Thanks!
Not bad, using them. Not as efficient as original but at that price, there is really nothing to complain.
Charlie_Zhan
Anyone interested in getting replacement Xiaomi air filters and wish to tompang on my order? Around $25 for the new enhanced green version (S1) and $2 more for the purple one.. it's original stock with RFID tags at the bottom..
Sent from Xiaomi REDMI NOTE 8 using GAGT
WussRedXLi
Thanks!
The TB DIY frameless 300 x 300 x 25mm HEPAs (25-30rmb ea) or those customised to 285 x 320 x 45mm (rmb 110-120 ea) are ok.
The 25rmb ones would convert the AX40 into a 200 m3/hr CADR min machine, capable of handling our indon haze PM sizes (tested) and also convert the AX40 into a lower dB SPL machine in high speed accordingly.
You will lose that 320 m3/hr CADR capability though. But no issue for those using in the bedrooms, even in a 20 sqm bedroom there is enough airflow for good ACH sufficient enough for say allergic rhinitis sufferers (min of 5x ACH, after factoring in the furnitures).
If one is using the AX40 for the living room of a 4-room BTO, inclusive of the bedroom corridors and main door corridor spaces, then you'd need to use the original Samsung filters.
Either that or change to a Xiaomi Gen 3, but do remember that at 320-400m3/hr CADRs it would still be significantly louder than the AX40, even though they tested the Gen 3 @ 400 to be a wee bit better in SPL than the Gen 2 @ 330.
The main issue now is that Taobao official forwarder (Cainiao) does not really ship these DIY type HEPAs via air ship already. They are forcing you to do sea shipping, and that'd be volumetric weight if i am not wrong.
And most 3rd party forwarders are more than happy to levy half-volumetric charges for such light items, cannot run one unless you are lucky coz you are just shipping 2pcs of 300 x 300 x 25mm and so it's not so immediately apparent to the warehouse workers doing the 入库.
PS. The only issue that some are complaining is that there is a slight smell (plastic) that the TB filter media gives off. This can be solved by airing the filter in lowest fan speed mode for 48hrs before using.
But still some folks find this to be an issue, coz that means 2 "missed" nights of usage.
So those pax would rather go for the originals @ SGD 90 each currently. The originals have activated carbon as well, but then the CADR for formaldehyde (if there is such an issue in the first place) is just 50 m3/hr CADR, not very high for such granulated activated charcoal type. (the xiaomi green one is even lower than this actually).
No issue, all are personal choices
hAiZzZ86
My Xiaomi airpurifer 2s died last week.
Totally can't power on.
Dismantled it today. But the power supply circuit looks alright.
Any suggestions?
Is there a repair center?
KusitoriBuro
my wife asked me to get dyson but i read online reviews say it's useless.
so xiaomi is the only viable option?
what if i need a fan + purifier like dyson? which model to get?
thank you thank you
Charlie_Zhan
thank you thank you
tilt the Xiaomi air purifier outlet to you and turn on max power lor.. :s13:
WussRedXLi
thank you thank you
Coz you are gonna be just wasting precious money.
The room's air quality in terms of particulate matter drop is pretty negligible with the windows opened if you are gonna be operating it as a fan. Also, you'd need to change the filter once every 2-4 months (filters aren't cheap in the first place). Unless if you really do not mind doing that coz you are earning really good and easy money.
The operational needs of fans and AP HEPA filters do not mix, unless if the filters are cheap (eg the rmb 25 HEPAs that i mentioned).
Lucky177
In case you missed my previous post, I don’t have Gen3. Only Pro. But methods of setup connection as far as I know, is still the same.
Didn’t have AP3. The usual setup procedure should be the same. Connect via 2.4Ghz wireless. Region set to China.
If all the above still does not work, last resort is to use two phones. One mobile hotspot to the other and use the other to setup.
Maybe can check with others having Gen3.
I’m using Singtel. Not on VPN.
haiz, tried all the methods already but really cannot...trying to eliminate all possibilities: your "source" for wifi, which provider? r u on any VPN?
KusitoriBuro
i dont open window. i turn on aircon all the time but also need fan when i sleep. my wife scold me for the fan being too dangerous (for kid) and dusty.
what is my best option?
