Air purifier? - Part 2
Vadher
Any recommendation for Xiaomi AP 4 Compact? It's lightweight and fairly unobtrusive can easily place one in each bedroom. The living room will probably need at least the 'Lite' version?
micromousez
Anyone has any review of Trident and Daikin air purifiers? These products no need to have filter replacements.
I bought Trident Plus when I am having Covid.
Luckily, my other 3 family members did not get infected.
Trident Plus is also very sensitive. Eg, when I spray hair spray in my master toilet, within 3 sec, the Trident Plus in my dinner area will detect it.
Easy to wash the filter
john doe 84
Dyson Air Purifiers - be warned that you might have a high pitch whine sound that occurs now and then. The only way to avoid it is to run at a low speed (4 or slower). Had this problem both on TP04, TP06 & TP09.
I personally like Dyson because it blows the purified air all around...faster way for clean air to reach all part of the room if you ask me.
I personally am KIVing a Samsung air purifier - depends on whether there will be haze this year and how bad it is.
Amitabah
Is adawo worth to get from TB? Or should I stick to Xiaomi AP? My recent Poiema kaaputt... Thinking which should I get. Poiema seems to be out of biz...
TIA!!
chaiscool
Anyone got try Xiaomi 4 Lite with older filter like 3h kind? Those older filter is cheaper, wonder if it’s compatible with 4 lite.
Lucky177
