Air purifier? - Part 2
jabbapapa
lol enjoy your csi. all i care is it works great at home. and sterra and many similar looking brands all confirm is oem
Lucky177
Can Xiaomi AP turn on using App or smart home?
Able to schedule auto on/off AP using XiaoMi Home app. Also under automation > create smart scene, able to set eg. auto on AP when PM2.5 exceed certain limit etc. That’s what I did for my 4 Pro and Pro H.
iicecube
Did anyone try b4 the honeycomb brand air purifier? Mainly I always close the window in my room and wanna reduce more dust, does it help reduce?
iCubes
Hi, any review on sterra air purifiers and HEPA 13 filters?
My office using. I think its very gimmicky with the touch buttons and the ball head covering and uncovering. More moving parts = high chance of breaking down. The touch buttons are also unresponsive sometimes. We only just installed and already see the touch buttons acting up. I wouldn't use my own money to buy these.
rznktoae
first time buying air purifier and i was abit fast in pulling the trigger BUT i just cancelled my order for Sterra Moon after reading this thread and some threads on reddit.
Space Gray model with UV - $299
True HEPA-13 Filter (3-in-1) x2 - $119.99
4 year additional warranty - $80
total with discounts: $478.89
i saw i could get a better deal. bought the exact same model Europace 3380Z instead:
EUROPACE EPU 3380Z (2 year local warranty) - $208
(from separate seller) Filter x2 - $70
total with discounts: $267.64
touchring1
Anyone blueair air purifier got musty smell? Mine bought about 6 years ago, changed the hepa once recently, seldom used but now got musty smell. Don't know if need to change the whole set.
Lucky177
I don’t have blueair. Instead of changing the whole set, maybe you can try to switch on the purifier without the filter (provided it allows you to do that) and see if there’s still musty smell.
If there isn’t, most likely is just the filter and not the purifier. Hopefully is helpful.
kairi kwan
Can it really help to remove odour? My priority
Can’t remove odour but can remove dust & other small particles, like fur (cos I have cats at home), cos I have sensitive nose that will easily trigger therefore this purifier help me a lot, hope this helps you
TheCoolDude89
Anyone has any review of Trident and Daikin air purifiers? These products no need to have filter replacements.
