Air purifier? - Part 2
LFC25
Seshuan, i posted the picture of the back panel of the Xiaomi 2 AP. It is 31W.
XM1 spec it as 75W (CADR 406m3/h) . Mfresh M8088A is 70W (CADR 580)
Back in office, here's the pic
can enlighten what does this 1.5A mean?
WussRedXLi
Found some pics of the 2 together.
Seriously, MFresh could shave ~ 12cm from the top. Don't know why did they leave that "empty gap" there between the top panel and fan assembly.
Don't tell me they will come out with a M8888A with a 60 cm height. !@#!@#!@
kandinsky
Seriously, MFresh could shave ~ 15cm from the top. Don't know why did they leave that "empty gap" there between the top panel and fan assembly.
Haha. Wouldn't be surprised if it was to match the xiaomi? E.g., If competitors' products are a certain size, my product cannot lose out, later ppl think less powerful/effective or what. :s13: Perhaps once one manufacturer dares to reduce size first, others will follow?
WussRedXLi
Haha. Wouldn't be surprised if it was to match the xiaomi? E.g., If competitors' products are a certain size, my product cannot lose out, later ppl think less powerful/effective or what. Perhaps once one manufacturer dares to reduce size first, others will follow?
Mfresh M8088A was built to follow Xiaomi 1 AP and added some touches to it (bigger filter, higher airflow for performance......slightly different shape with curves, maybe some like maybe some don't). Now that Xiaomi 2 is out, I guess the MFresh CEO would wanna stir something in order not Xiaomi 2 to cannibalise much of its sales.
Furthermore, XM 2 AP at RMB699 is really competitive.
MFresh is not a small brand in China for health products. Of coz they don't manufacture phones/pads and stuff like that.
New one
Well, you want slim and tall to save on footprint, here it is. It should fit nicely in a 4/5-room HDB hall's corner. No need to position much, 900 horse power ensures single digit ug/m3 even at 471 ug/m3 external!
Dafug.
WussRedXLi
And remember, there really is a lot of "media" in the MFresh stuff.... though you pay slightly more for it of coz.
WussRedXLi
One good thing that I gotta mention again with these Mfresh and Xiaomi APs, is that during hazy months, you can just switch it on from your phone in JET mode for fast clean when you are on the MRT a few stops away from home. So when you reach home 15-30 mins later, the home will be all clean.
Eg, a Mfresh M8088A can clean a whole 110 sqm 5-room house in 30 mins in JET mode after which it'd auto-throttle down to Speed 3. Just site it in the MBR and the haze particles would diffuse ard the house. The efficiency drop is very slight, time is on your side anyway with remote control. Either that or you time it Auto-ON at say 6pm.
So you don't have to bother with simi "rotational cleaning" by moving it into each room etc. Troublesome leh...
WussRedXLi
Mfresh M1 and M2 just released today only.
http://www.prnews.cn/press_release/168271.htm
瞄准大空间 净美仕推空气净化器商用机超人系列
2015-11-26 08:40 来源:商业电讯
随着雾霾的频发和人们生活水平的提高,人们开始认识到室内空气污染的危害,迫切需要解决室内空气品质问题,保证家人的健康。空气净化器应时而生,大大的解决室内空气污染问题。家用空气净化器日渐普及,商用机日渐受到办公室、商超等大空间的青睐,净美仕应时而为,推出超人系列商用空气净化器。
作为深耕空气净化器领域的净美仕,12年来,已经形成了“家用”、“车载”和“新风机”大系列的全线空气净化和新风系统。既有面向学校、酒店的新风系统;更有针对品质生活家庭家居环境净化的高效净化器,还有车载净化器等便携式的个人系列产品。净美仕从不同角度加大研发和创新力度,不断推出新的产品和解决方案,以帮助政府、企业、学校及家庭应对空气污染的挑战。2015年,净美仕瞄准大空间,再次出击,首推超高CADR值大型空气净化器超人系列M1、M2,并开始了在楼宇、商超、医院、机场、别墅、综合办事大厅等空气净化器商用领域新布局。
超人系列具有超大CADR、超强金属机身、超大容尘量、超准净化数据、超大适用面积 及超精确传感器等超级特征。采用多套一体桶形滤芯,双风机双过滤大风量运行,并可进行加湿定制,净化效果可视,智能操控,手机APP控制。超大滤网,可同时去除颗粒物 (PM2.5)、细菌和各种异味的全能空气净化机,净化能力是同类产品的两倍以上。
净美仕此次推出的超人系列分为M1和M2。M1采用双风机双滤网过滤, CADR值高达900m³/h,适用面积63-103㎡。M2采用双风机4套滤网过滤,CADR值高达1200m³/h,适用面积84-144㎡。实现分层净化,全方位多维度立体进风系统,超大风量,对固态、气态污染物净化效果均达到A级别。若将超人系列安放在超过100平方米的大空间,它可以在15分钟内完成整个空间的极速净化,为大型公共空间提供了便捷高效的空气净化解决方案。
净美仕为超人系列配备了三种超大桶形滤芯,综合治理PM2.5/甲醛滤网、强效除甲醛专业滤网、除烟滤网,每台机型标配为2组综合治理滤网,满足不同空间需求。
超人系列机身顶部和机身下部出风,最高出风可达8米层高。进出风循环采用分层设计,上下两个风循环系统隔开,上部采用四周循环进出风,下部采用左右进风顶部出风,分别在独立高效双风机的作用下,将洁净空气送到远处,顶部的洁净空气直接送至天花板,形成360度、多维面的流动,使空间内快速实现大循环净化。
采用全金属机身,高密度合金钢材,防辐射且不易变形,汽车烤漆工艺,完美提升品质,超强的合金钢材完美支撑360°打孔设计,有效进风面积比一般净化器高4倍以上。
机身触控面板,实现净化效果可视,搭载超精准传感器,屏幕上精确显示室内外PM2.5,室内温湿度等,并可以实时调控档位。
超人系列还实现了智能操控,只要通过手机端APP就能随时监控放置空气净化器的室内的空气质量,随时随地掌控空气质量,无论室内还是在室外,都可了解空气净化器室内的空气质量,根据空气质量检测数据实时急速净化,随时控制空气净化器的净化效果。
生活品质日渐提升,如今我们不仅要求家庭生活环境的空气要好,在商场逛街、在健身房锻炼、在会议厅开会的时候,都希望能够处于一个洁净健康的空间,而净美仕超人系列的出现则完美的满足了这一需求。
patcheon
Philips seems to have smart APs too, but did not see it in the local Philips website. Think China have.
http://www.shop.philips.com.cn/item/AC4373-00
http://www.shop.philips.com.cn/item/AC4375-00
WussRedXLi
Looks like the typical TB street price for XM2 AP is 818. Ie they source available stocks for you and you pay 818.
Probably will only be 699 well after CNY when the NE China haze clears. That's what happened for ver 1 also (i think they released in 2014 aug, lagi earlier)
Lucky177
I managed to grab the $100 Black Friday Qoo10 voucher. Very tempting to use it on another AX40. If only Mfresh or Mi2 is available in Qoo10. :s13:
patcheon
The new Gain City Building at Sg Kadut have one Giant Samsung (I think) AP on display. (If I did not misID an airconditioner or some sort of speaker as a AP. :p)
