Air purifier? - Part 2
WussRedXLi
The new Gain City Building at Sg Kadut have one Giant Samsung (I think) AP on display. (If I did not misID an airconditioner or some sort of speaker as a AP. :p)
Like this?
Asakura
oh the m1 m2 looks cool haha
a lot of gers are around 1.55-1.65
imagine having a AP taller or same height in the house lol
Lucky177
Ya...something like this..just that I can't recall clearly got 2 or 3 disk thing on top. Saw it couple of days back...old liao. :s22::o
If is 2 disk thing, then probably is the AX90 air purifier
http://www.samsung.com/sec/consumer/living-appliances/air-cleaner/air-cleaner/AX90J9000WKD
But I doubt is available here. So probably u saw is the 3 disk thing, which is an aircon AF28
http://www.samsung.com/sg/consumer/home-appliances/air-conditioners/floor-standing/AF28FVSDAWKNST
patcheon
WussRedXLi
根據實測,小米空氣淨化器2代最強 Turbo 模式會產生 63.5分貝的噪音(標準模式最高為58.2分貝),1代最高為70分貝;功耗2代最高54W(睡眠模式1.7W),1代最高82.1W(睡眠模式4.2W),兩者的差距相當明顯。
WussRedXLi
Don't take the above numbers as absolute since there is always a margin of error, but as a frame of reference. (vs mindgamey's or seshuan's wattage and dB numbers)
Eg above mentioned XM1 as 82.1W in jet, but seshuan measured 73W. Official = 75W
The slight drop from XM1's CADR 406 jet down to XM2's CADR 388 jet (or 330 std high) is probably more than acceptable for 99.9% of the folks out there.
But it seems that it's doing ~50W for 388 m3/hr. 31W is for 330 m3/hr.
Bottleneck at the filter or fan end but understandable for such a smaller unit.
Samsung AX40 is 35cm x 20cm x 48cm = 33600 cm3 (700 cm2 footprint)。 Single useful speed as High, 323 m3/hr CADR @ 27W
XM2 is 24x24x52cm = 29952cm3 (576 cm2 footprint) CADR 388 @ ~ 50W or CADR 330 @ 31W
XM1 is 26x26x73.5 = 49686cm3 (676cm2 footprint) CADR 406 @ 75W or CADR 271 @ 30W.
MFresh M8088A is a bit too large to be directly compared. :s13: (33cm dia x 71.5cm = 62k cm3). But it does give CADR 326 m3/hr @ 27W and is maybe 0.5 to 1dB more silent than the AX40 @ 323 m3/r @ 27W.
Of coz it is capable of 45W @ CADR 520 as well, or maxes out at CADR 580 @ 70W
The AX40 and M8088A @ 300+ m3/hr range run dB numbers noticeably lower than XM1, and possibly XM2. The dB noise figure at operating speed is crucial for those light sleepers, and from what I learnt in 2015 Haze season in this and the 2015El Nino/Haze thread, there are quite a fair number of these folks.
This low 300+ m3/hr range provides an excellent ACH number about 7-8 ACH in a typical BTO MBR + typical furnitures, which will be useful for people in the Sensitive Group. Deployed in a BTO bedroom which is even smaller = 没马跑。
MFresh and the XMs have remote control wifi/cloud function, very useful during hazy months so that you can control before you reach home or set some on/off timing. Normal days, not so useful.
WussRedXLi
Put it this way, the XM2 is the most "CADR power dense" AP in the above compario. It has the most horsepower per cubic vol. It may or may not be critical to you.
clay9477
Quite curious on the new xiaomi air purifier 2 fan motor. They r&d the fan motor but didn't mention who manufacture the motor. Previous gen 1 at least mention japanese motor.
WussRedXLi
Looks ok...... well packaged. Not double boxed though (my Midea KJ30NV is double boxed, but of coz I got it locally from carousell)
WussRedXLi
I managed to get one piece and it got sent out today via 顺丰, but is more like ordering on behalf of another bro. So yeah, the stocks are in.
