Air purifier?
Zabiyaki
Bought this last night. Need to use the ns vouchers and some ntuc vouchers before expiry date. :(
The specs in the instruction booket stated that the applicable area is 15m2. The hepa filter is not rated, filter 0.3 µm with efficiency of 99.9%.
Good enough for my bedroom.
Sibei sian
This looks like the cheapest one so far. What replacment filters does it use and how much?
Keep waiting for the sharp a28e to drop in price but instead it keeps going up..wait until haze come liao still havent drop:vijayadmin:
jarred1223
Using a sharp one.. Bought since last year turned on until now still working fine :D
MMike should be able be this model FU-Y30E
Doraemon70
Anyone has any idea where still have Sharp KC A40E or KC A50E or KC D40E or KC D60E and any idea what's the price? Thanks.
mosmos
High Honorary Member
Is it?
Why more mozzi everywhere now?
Evidence by kid who suffer mozzi bites just these few weeks
Before this, nothing at all
Now, kid has to stay indoors, don't know need to buy how many filters then enough
:s22: haze not strong enough noted, Indon will pump more into sg to get rid of mozzie~
NWT1978
but this brand lasting? filter able to get easily?
NWT1978
which store? SIC leh :D
it call T.S. Yong Trading...
Boss friendly, you can PM him for reserve...
Pay by Cash / Nets.
But then it seem out of stock too. Boss said due to financial year so little production, stock will came in April 2014 to May 2014...
test out this one tonight... if useful...thinking of getting another one... maybe from same store again... since can reserve one through FB lol=:p
https://www.facebook.com/tsyongtrading
We are open from 10am to 9pm tomorrow from Monday to Saturday and 10am to 3pm on Sunday.
Location: Blk 118 Aljunied Ave 2 #01-126 Singapore 380118
Phone: 6749 0285
See...even Sunday open:D
Tyrian
mine another model by Sharp... store say got stock...reserve one for me... @ 199...
will go down later to see if true or not :D
maybe got stocks for other Sharp models too :D
Can sic which model?
Asure7
Still using 6-7 year old Sharp FU-S51E, just changed filter last year.
V good workhorse, still working strong.. with the specs better than many of the newer models (closest same spec new model is A50 i think).
Wanting to buy one more, but not sure which model to get....
Wonder why Sharp decided not to have HEPA-13 filters in non-humidifier models anymore :(
derazor
If the AHU is using decent MERV-9 or MERV-10 filters, actually no need air puirifiers. Coz the a/c room is not exposed much anyway, much less exposure to external air compared to HDB. HDB is usually return home then close windows switch on purifier and a/c.
MERV-13 is like close to HEPA-12 liao.
Not saying these are the ones, but are similar to these....just that the commercial ones are much bigger and slightly thicker at 3-4 inches.
Nordic Pure 20x20x4M13-2 20x20x4 MERV 13 Pleated AC Furnace Air Filter, Box of 2, 4-Inch - Amazon.com
Bro, where to get the filter the cheapest ah? don't mind to wait no hurries.
Those honeywell if import from Germany, they can move air even better than the KC Sharps?
But I felt the honeywell takes more estate space hor?
The new KCD Sharp has the haze feature is quite good. 1st hour purge all the dust.
Zabiyaki
NTUC selling Taiyo`s for $99. But size is slightly larger then bread toaster.
Saw it earilier..decided not to buy, not worth le, too small. From Qoo, filter sells for about 60$. For such a small purifier sure must replace dam often
Whats the cheapest sharp air purifier avail now?maybe can preorder in case wind change
Zabiyaki
got the Sharp FU-Y31E=:p
better than nothing=:p
Boss said better not use transformer... warranty dont cover this one if spoilt it...:(
Whats the dif between that and FU-Y30E? One got odor sensor and the other doesn't?Does Haze fall in the odor category?lol
NWT1978
dont know lol...
I hope it good enough... wait stock came...maybe get another one =:p
blues7
Ok been reading about different brands etc
Confirm Honeywell and sharp lots of supporter
Personal experience tell me any brand as long as can work and meet some standard that are important to filter air should do
Most importantly, must be able to get replacement filter
mosmos
auto fan speed roh, to moi not much use, juz blast to full speed more comfy when got haze~
sometimes auto speed to lowest, sensor show clean, then chiu smell haze bery uncomfy tik air purifier must be spoilt~
WussRedXLi
Stuff like Novita will work. Just that they are not as well-known and are new. E10 = 85% @ 0.3 microns, will work. H13, 99.97 @0.3microns, will work. Likely E10 will be > 90% efficient @ 0.75 microns.
Sharp and Honeywell been tested. Sharp more of well-known locally, plus replacement filter support. Not only that, Ebay support as well.
Sharp and Honeywell are WORKHORSES. 10 years, not likely to be an issue.
Mine has been running daily 12/365/6 years. Another got FU-51 running for 7 years?
Spend $400-800 for a 10 year workhorse, nowadays not many electrical appliances can do that.
IQAir and Blueair are the high-end workhorses. In price-sensitive Singapore, I guess they may not do as well as their lower priced counterparts. And of coz got the not so popular workhorses like Austin mate etc...
WussRedXLi
The KC-D60 or KC-A50 quite power liao. Both have a CADR of low 200s.
Compare with the Honeywell 50250 with CADR of 250.
Size you gotta compare yourself. By square area, the 50250 takes up more space. There are other models, gotta compare yourself.
Electricity....50250 takes 50W/120W/170W. Sharp is 5W/18W/46W. Almost the same CADR probably - check out the noise levels for comparison. The Honeywell is noticeably much noisier for the same CADR (even lower speeds).
But the 50250 has the best bang for the buck in CADR per dollar $.
Different pple, different uses, different strokes.
I use everyday for years. Noise and electricity consumption is number 1 factor. The difference between the Sharp and HW 50250 is at least $150 difference in electricity cost running in medium speed. 6 years = $900.
Some just use 7 days per year. Performance is number 1 factor. Electricity and noise, simi lai de? :D
blues7
Need to use air purifier everyday ?
Bought iLife years ago, use for a while then find not much difference without
Also used sharp purifier before, about same time as iLife was available, same result
Only last year, when haze become so terrible then re-activate iLife
Remembered feeling glad not to have given iLife away
Now buy Novita becoz have online eshop
Need to add that I've tried 3m filter with Aircon before too, many years back when 3m was first launched
Same thing, yes, filter turn grey but feel not much difference without, just clean Aircon original filter more often
Then there's the mask, last year rush to buy but hardly used becoz very uncomfortable
Now, just hope rain come soon
Forecast said east side to have thunderstorm but as of now, no sign or water vapor even, just thick smoke, like every night before tonight
Sian
