Air purifier?
lala81
Selffix has it in different length etc. Been using for a year...i just slot it under self in bombshelter
for wardrobe mb can use this
But can actually just buy loose silica gel and "fry" in wok when turned pink
Silica gel not cheap. Even in TB, it's about 4+ bucks per 450gm without shipping. For one bomb shelter, think i need sibei a lot.
Maybe i just try the dehumidifier that i found.
The one you show is just a heater element. I think quite hard to heat up 1 entire bomb shelter as well.
I will take a look at the one u showed. THANKS!
Akai Ryu
It does feel like sauna when i enter my bomb shelter at times :o
WussRedXLi
Don't get those silica gel or even Thirsty Hippo. There is more moisture that needs to be wicked from the air than a layman thinks.
Give you eg, air-con. Last time my mum's house, the drainage pipe drains to a big 25L pail one, not to the drain. Every night switch on air-con, if you switch on cold enough it would be 3/4 pail full. Of course that's for a bigger room + the room is not leakproof. But then again, the humidity did not drop to crazy low 30-40%.
That's like 15-20 litres of water. There is no way 5kg of silica gel or 1-2 packs of dozen thirsty hippos is able to sustain that kind of wicking moisture from the air.
That is why need to get a proper dehumidifier. Once it does it main work of dropping from 70-80% down to to 30-40%, the humidity would stay there as the bomb shelter is literally air tight. Whenever you open the door, some moist air would get in there, the dehumidifier can level it down again.
Else it'd be a heck lot of work.
WussRedXLi
wrx,check with u...the samsung ax40 is true hepa or not? nv see the word true hepa leh...sadz..
It's H13 standard, aka True HEPA. Don't worry too much about that coz in real life when talking about the whole system efficiency, it'd be quite a bit lower than 99.97%. :D A lot depends on the sealing and the filter quality, in which as long as it's not DOP tested and certified, then nope it won't be approved for use in Cleanrooms, hospitals etc.
In real life, the airflow matters a lot too, in fact it's matters more than whether it's H10 or H13. Of coz don't pull in a middle-coarse filter like F7-F9 grade and compare.
The Samsung AX40 really flows quite a bit of air in high-speed mode, at the lowest dB/noise level I have ever come across at that airflow (323m3/hr), at the lowest power consumption. It helps that on qoo10, it used to go for $265 - 285. Now a bit more ex at 300, but still great.
AX022
Air Purifier AX022HC | SAMSUNG Singapore
WussRedXLi
Sealing is like your KN90, N95, N99 etc.... You don't seal properly, forget about it.
But most consumer based APs mentioned here are pretty decent in sealing. Just stuff some more cling wrap or tissue paper at the sides if you are ngeow.
And even then, does that matter IN REAL LIFE when the whole room is not supposed to be sealed tight anyway, else how to breathe and maintain O2/CO2 over a few hours?
That is why the airflow/Clean Air Delivery Rate is more important in our consumer setting and usage.
lala81
My thoughts exactly. Think i'll just buy a dehumidifier.
WussRedXLi
http://environmentalresearchweb.org/cws/article/news/59424
Nov 26, 2014
Climate change set to boost Sumatran wildfires
October is a worrying month for firefighters on the Indonesian island of Sumatra. As the dry season draws to a close, wildfires spring up all too easily, often resulting in the destruction of vast tracts of rainforest. Now, a study has revealed that climate change is making the problem significantly worse.
The difficulties spread beyond Sumatra. During 2013, much of Singapore and southern Malaysia were shrouded in thick smog caused by the dense smoke billowing across the Strait of Malacca from Sumatran forest fires. Schools in Malaysia and Singapore had to close, and people with respiratory ailments and heart conditions had to stay indoors. This was no one-off incident. Large fires spark up on Sumatra most years, destroying forest, pumping vast quantities of carbon dioxide into the atmosphere, and smothering countries downwind in a toxic haze.
Many of the wildfires on Sumatra are triggered by "slash and burn" deforestation going out of control. But the ease with which fires start appears to be increasing, and many speculate that climate change is also playing a role. To investigate, Kartika Lestari from the University of Tokyo in Japan and colleagues used sea-surface temperature to drive two atmospheric general circulation models – one with and one without an anthropogenic warming component.
Focusing on the period between 1960 and 2011, the researchers showed that climate change has increased the frequency of drought in this region by around 20%. "We show that a weakening of the 'Walker circulation' [the easterly trade winds that move water and warm air to the west in the tropics] is associated with tropical ocean warming, which leads to a robust decrease of precipitation over Indonesia, and consequently the increase of drought frequency in Indonesia, including Sumatra," said Lestari, whose findings are published in Environmental Research Letters (ERL).
Looking ahead, Lestari and colleagues analysed Coupled Model Intercomparison Project Phase 5 model ensembles. They observed an increased drying trend over Indonesia, amplified by enhanced surface ocean warming in the central equatorial Pacific. The ensembles indicate that the reduction in rainfall will lead to a further 25% increase in severe drought events in the region by 2050, compared with now. "Without wiser reforms in land use and large caveats, this suggests that there will be more severe fires in Sumatra," said Lestari.
There is little that can be done to stop the droughts, but there is still time to take action and reduce the incidence of wildfires. "Biomass burning could be reduced by introducing stricter government policies and enforcing the law to limit logging by using combustion," said Lestari. Of course, it is not just Sumatra that will benefit from bringing the wildfires under control: the surrounding countries are keen to solve the problem too, ensuring that everyone can breathe easily.
WussRedXLi
Other than the above long term general "drying", still looms the threat of El Ninos.
WussRedXLi
strange spike
Sent from GAGT Android App
Yeah man, but do check out my Super typhoon Hagupit update thread. Think you are reading that right. Should last for the next few days till mid next week.
Interesting, very interesting indeed.
The PM should be from Sumatra area. Peninsula Malaysia has been whacked by too many thunderstorms + widespread rain, as seen on the weather radar which I have been monitoring v regularly.
tmkedmw
WussRedXLi
Haze disrupts flights over Sumatra | The Jakarta Post
Sumatra
The Jakarta Post, Batam, Riau Islands | Archipelago | Thu, December 04 2014, 8:05 AM
A Lion Air plane that departed from Hang Nadim International Airport in Batam on Tuesday afternoon was forced to return to the airport as its the destination of Pangkalpinang airport was closed due to thick fog.
Hang Nadim airport general affairs head Suwarso said the plane departed at about 1 p.m. local time on Tuesday but turned back after flying some distance as Pangkalpinang was closed.
“The Lion Air aircraft departed but returned to Batam due to safety concerns as Pangkalpinang was closed. The plane departed again in the evening,” Suwarso told The Jakarta Post on Wednesday, adding that several airports in Sumatra were still being disrupted by haze.
“Some airports, such as Sultan Syarif Kasim II in Pekanbaru, Sultan Thaha in Jambi as well as airports in Palembang and Pangkalpinang were overshadowed by haze,” he added. (***)
WussRedXLi
This also proves that the thunderstorms that have been happening in Sumatra for the past 1 month were unable to fully extinguish the peatland underground fires.
Still smouldering and waitinf for 2015 haze season + dry season there.
Akang datang.
I guess there hadn't been torrential rainstorms for 7 consecutive days.
