WussRedXLi
- Jun 15, 2001
Bought 8 filters in total. I have ALWWed the seller, they are using H12/HEPA-12 quality filter media.....hence that's 99.5% @ 0.3 microns thereabouts.
Not the other one who was using F9 which is lower grade.
544/8 = RMB 68 each on average. 30mm and 39mm thickness. Not too bad. FZ-200 model is for the KC-840 and A40.
ÏÄÆÕ¾»»¯»ú¼¯³¾¹ýÂËÍø¶¨×ö(ÊʺÏKc-W380Sw/FZ-200HFS/FZ-280HFS)-ÌÔ±¦Íø
You can alww them to customise. I just purchased off-the-shelf and cut, coz then ready stock and can send out within 12hrs. (coz I have current shipment with 4PX and don't wanna wait anymore)
Thanks for sharing! time to top-up filter for my AX40!![]()
Pls note, this is not the previously mentioned 30mm and 39mm thickness.
I have ALWWed the seller and it's 31mm for all models.
Stock for A40 is 31mm depth but the cavity can handle up to 40mm. Stock for Novita NAP501i is 20mm, but the cavity can handle to 40mm. These are the ready-stock OEM models for the few air purifiers which are the china equivalent of Singapore models (eg China Sharp HF-200 or HF-280).
The models are not suitable for Samsung AX40, which needs to customise.
