Air purifier?
kendoarts
Renovation construction dust is probably coarse type PM10 or bigger.
Is definitely a risk in your new house, I have experienced before. Everyday wipe once also not enough due to neighbours. My 7 blocks got a total of 1878 households renovating at the same type. :s13:
Remember, your baby is the one staying at home 24/7, maybe you'd have parents coming over to take care for the first few months. Parents go to work in Grade AAA offices in MB, Somerset/Orchard, Suntec, Shenton Way, AHUs all equipped with F9 grade filters that would clean the air to safe 24-hr levels even if outside were PSI 300.
http://www.hse.gov.uk/construction/faq-dust.htm
Novita, a bit expensive lah. Sometimes there are offer. Novita is a local brand but some models are China factory taobao models + 加工 and using better motors etc.
You don't have to add filters. I am talking about utilising the Sharp A80, but you probably would want coverage for living room PLUS bedroom coz it's not feasible to get holed up in a room for > 50% of the day/night. So you would need some auxillary filtration. 3M Filtrete is the affordable answer.
Picture this, you have an extremely powerful 28k BTU/hr aircon in the living room. You master bedroom would be cold, but just a bit. Would be nice if you have another mini aircon that's 3000 btu/hr inside + some fan to circulate the air from the living room to bedroom.
NEA and ST is keeping pretty mum this year round with regards to haze forecast compared to last year.
Try to leave a bit of gap in the doors/windows in the room that your baby is in, to prevent formaldehyde build up due to new furnitures. This places additional performance demands on your air purifier, so a Sharp A80 + 3M Filtrete would definitely be good.
WussRedXLi, appreciate your kind inputs and expertise.
I have tried to look for Sharp A80, but I can't seem to find it at Courts. Do you know how much does it cost and where got sell this model ma?
WussRedXLi
Oooo any idea about Philips model? I quite noob on this... No la no advert yet but Philips is having their Warehouse sale ma this weekend at TPY
Sent from Sent from iPhone 3G using GAGT
From my cursory glance at their models, I think can skip. The output very noisy relative to the airflow. This is esp important for the bedroom where folks will be sleeping. Noisy appliance = useless device.
WussRedXLi
Google for Goh Ah Bee (Kovan). Lion City electronics (geylang, opp Lorong 39). And some if you usual neighbourhood stores. Hope you can get it for $459 (maybe nego to that price), but I reckon $475 can get.
WussRedXLi
Any effect if i put a sharp deodorizer filter on top of AC intake
Yes, got effect. But very expensive effect and seriously unless you have several KG of activated charcoal, it's gonna be slight.
Those deodorizer filters lose their effectiveness in just 2-3 months. I'd say, don't bother. Clean out your source smell, like changing out the bedsheets more frequently.
chuanz
This too. Anyway Philips is not a major player in AP. Like I said, got mine in 2013 haze period. You can sell a no brand AP for $500 and still it'd be sold out in no time.
orangeman
Icic thanks, won't be putting in bedroom but in a small shop instead..hmmm then will look out for the prices on weekend
edgefield07
I saw best denki selling around $559, is it the same model?
too bad I have the gift vouchers from best.
Sent from Samsung SM-N9005 using GAGT
BrOwnTeddy
If you are going to use these for daily use as a bid to reduce the need for washing the fan, don't. It reduces the airflow quite a fair bit + increases noise levels.
Can use this if it's for haze. It's just the 3M Filtrete in circular form so as to fit fans
RMB19.90 only, think got buy 2 free 1 promo.
http://item.taobao.com/item.htm?spm...62661&ns=1&_u=a1u0hcib38cd&abbucket=10#detail
Woah. Good stuff man. Can use it for the house fan and air circulator.
Need to look at humidifier cum air purifier also now. Luckily that day didn't backside itchy go and hoot air purifier.
WussRedXLi
Depends on your needs and wants ba. But its really low cost here (Amazon raised its price from usd4.97 to usd 9.78 liao). Each pack v light weight, less than 100g so 4PX cheap also.
AP is still needed for those in sensitive grps if you are guarding against > 3hr PSI 80.
Healthy pax, this would be good till maybe 3hr PSI 200?
Living room would need 2X of this, assuming doors/windows fully closed (aircon up to individual to arrange).
WussRedXLi
Finally, BOM Australia has a slightly higher threshold @ 0.8 deg C anamoly (JMA and NOAA = 0.5 deg C). El Nino status for BOM.
http://www.bom.gov.au/climate/enso/
El Niño in the tropical Pacific
Issued on 12 May 2015 | Product Code IDCKGEWW00
The tropical Pacific is in the early stages of El Niño. Based upon model outlooks and current observations, the Bureau's ENSO Tracker has been raised to El Niño status.
El Niño–Southern Oscillation (ENSO) indicators have shown a steady trend towards El Niño levels since the start of the year. Sea surface temperatures in the tropical Pacific Ocean have exceeded El Niño thresholds for the past month, supported by warmer-than-average waters below the surface. Trade winds have remained consistently weaker than average since the start of the year, cloudiness at the Date Line has increased and the Southern Oscillation Index (SOI) has remained negative for several months. These indicators suggest the tropical Pacific Ocean and atmosphere have started to couple and reinforce each other, indicating El Niño is likely to persist in the coming months.
International climate models surveyed by the Bureau indicate that tropical Pacific Ocean temperatures are likely to remain above El Niño thresholds through the coming southern winter and at least into spring.
El Niño is often associated with below-average winter and spring rainfall over eastern Australia, and above-average daytime temperatures over the southern half of the country. However, the current May to July outlook suggests much of Australia is likely to be wetter than average. This is because a warmer-than-average Indian Ocean is dominating this outlook. El Niño is expected to become the dominant influence on Australian climate during the second half of the year.
Next update expected on 26 May 2015 | print version
Kinetic
Can i use an AP in an non-enclosed room (cos bedroom no aircon)? How to calculate in such case?
WussRedXLi
From what i have measured in a v small room (new BTO small bedroom) and a powerful air purifier like the Samsung AX40...the PM2.5 levels only dropped 50% with the windows closed and doors opened. (This is not the PSI or AQI level)
Not v effective at all, and you are likely to wear out the HEPA v quickly like within 3 months if it gets moderately smokey.
orangeman
Hey Bro, went through most of the pages seems like the model LG LA-Q379SB is quite good.
Can ask you any difference between the 378 and the 379?
For the DIY of the filter i saw the link you share for Taobao, so i just follow the dimensions you share and quote them the model i want?
cheapest now on Q010 is $278 now ok right?
pai sey i alot questions:o
