WussRedXLi
- Jun 15, 2001
planning to get a air purifier.
need to consider what ?
dont understand the terms xxx mg3/hr
and noise factor as well?
also my window facing a main street (2 lane road), about 10 stories high about ground.
the dust particles are alsoand i got sensitive/dry eyes
Just have to consider design, power consumption, noise factor, airflow output. You do notice that I did not put filter performance.
Note to others as well : Don't worry about wanting to get the best of the best filtration that money can buy. My wife/I can get 2k+ IQAirs, but we didn't + that's not the way to spend money. Unless one has a pre-term infant who just underwent ops and is discharged from the ICU, one would not need that.
That kind of filtration, perhaps unexpectedly, comes from Cleanroom FFUs (Fan Filter Units) with a U17 ULPA filter. ICU/HDUs use that kind of cleanroom filter as well, 600mm x 600mm square size. And perhaps unexpectedly to some folks, you get that from China eg Taobao too.
Cleanroom type of HEPA filter @ Mount E HDU. I don't think they use ULPA.
I'll just list out which ones are popular in this thread.
1. Samsung AX40. 323 m3/hr 190CFM 27W as measured, 34W on specification.
45dBA (among the quietest out there). Replacement filter $88 shipped.
Search : http://list.qoo10.sg/s/SAMSUNG-AX40?keyword=samsung+ax40&keyword_auto_change=
1a. Samsung AX60 or AX70, get from qoo10. It's like 2pcs of AX40 stacked. 773 m3/hr. Unlikely you'd need such a powerful machine for HDB.
3. Sharp A50 or A80. Sharp A40 is on the small side.
Vivo BEST has the A50 on offer at 439 but not sure if it's still available now. 309 m3/hr airflow and 49dBA. Power 41W
Nevertheless, the A80 has good value too, 480 m3/hr airflow and 51dBA.
That's high speed, you switch that on for initial 30 minutes. In medium it is 300 m3/hr and 41dBA so it's even more silent than the Samsung AX40.
Replacement filters are all available at BEST, I think $109.
A80 can get from lioncity from geylang, or Goh Ah Bee from Kovan (google). Slightly more than $100 cheaper than shopping mall retail.
Special mention : LG LA-Q379SB on qoo. (it's the Korean model of the local retail LG PS-R459). 318 m3/hr airflow. 186CFM
40W. 47dBA. Replacement filter is not available in retail, have to customise the HEPA filter on Taobao. But it's easy if you are a Taobuy buyer, lots of sellers on TB who are able to do that, just need 24 hours of lead time.
But if one is not internet shopping savvy, then can't be helped. Have to get from SG retail.
