Air purifier?
WussRedXLi
My sis just texted me saying sunset way area the haze smell is damn strong!
ok lah.....there's a smell, but not VERY strong. :)
50 ug/m3 PM2.5 on my meter.
But NEA is usually lower a fair bit. Perhaps 40-45 ug/m3?
Batam island is totally obscured. Jurong island smoke stacks/chimneys are nearly obscured, barely could see the outline.
WussRedXLi
Seems to have deteriorated a bit since last post. Now meter showing 65-70 ug/m3.
Peaked at 75 ug/m3.
Got thunderstorm coming also.
WussRedXLi
Thunderstorm south side, dropped to 30 ug/m3.
No 20 ug/m3 range. Dropped very fast due to thunderstorm.
chuanz
Distinct smell up north, outside Causeway Point. Very distinctive, probably the "strongest" smell this year.
WussRedXLi
Got people posting in other threads regarding the smell. My 2 meters showed the rise. But interesting readings from NEA.
chuanz
Yes, NEA readings does not always show the rise. Sometimes it would show up but a couple of hours later (vs my own monitoring).
I have no idea why, but I have been relying on my own monitoring more as there may be (probably not in this case?) localized conditions that affect me more than NEA's sampling points.
WussRedXLi
Can see liao. We just need the winds to turn a bit Southerly.
So it probably wasn't SE (Kalimantan) haze as earlier thought.
WussRedXLi
Banjabaru is @ South Kalimantan
BANJARBARU, Jam 0 : 41.74
BANJARBARU, Jam 1 : 61.12
BANJARBARU, Jam 2 : 51.36
BANJARBARU, Jam 3 : 92.60
BANJARBARU, Jam 4 : 104.73
BANJARBARU, Jam 5 : 75.97
BANJARBARU, Jam 6 : 102.90
BANJARBARU, Jam 7 : 294.87
BANJARBARU, Jam 8 : 398.07
PALANGKARAYA, Jam 0 : 144.58
PALANGKARAYA, Jam 1 : 146.13
PALANGKARAYA, Jam 2 : 167.86
PALANGKARAYA, Jam 3 : 216.34
PALANGKARAYA, Jam 4 : 228.30
PALANGKARAYA, Jam 5 : 216.64
PALANGKARAYA, Jam 6 : 216.50
PALANGKARAYA, Jam 7 : 221.55
Read more: http://www.bmkg.go.id/BMKG_Pusat/Kualitas_Udara/Informasi_Partikulat.bmkg#ixzz3j7altFO3
chuanz
North: 44 ug/m3
South: 69 ug/m3
East: 63 ug/m3
West: 96 ug/m3
Central: 53 ug/m3
WussRedXLi
Just to time stamp 19th August 2015
WEST side 1900-2000h = 98 ug/m3.
98 μg/m³ (PSI 145 / AQI 173)
WussRedXLi
First time I kena eye irritation. (usually is headache)
And very fast too.
Fug the 24-hr PSI.
Washed and in air purified room now + AC.
chuanz
This is from one of my particle counters. A burst of 10 readings is taken every 5 minutes.
The vertical cliff at the end is the AX40 kicking in.
chuanz
p/s: the relatively gradual slope after 10:30-ish is due to "leakage". One of the top hung window panels was open.
