Air purifier?
NWT1978
Tried several times to buy AX40 on qoo but cc cannot process...donno why...:(
then go by internet banking... unless u want go through by 7-11... this method will take 1 week to process payment... only if u are not urgent :s22:
krazedout
Thanks bros for this informative thread, esp chuanz and WussRedXLi. Went out and hooted a Sharp A50 because I didn't want to wait for qoo10 shipping. Last minute hug buddha leg. Overall quite satisfied with the A50, but I think the AX40 is definitely more worth if you can tong the shipping time.
Was wondering though, after reading WussRedXLi and Ryu's experiences on mold growing on the humidifying wheel, (Post link: http://forums.hardwarezone.com.sg/86061869-post1302.html) it seems like mold will grow even if you don't use the humidifying function, as long as you've used it at least once before? I've already used the humidifying function already, but I'm a bit lazy to clean the humidifying wheel all the time. (Will only deploy the A50 for haze period) Any bros know if I can prevent the mold from growing if I clean and dry the wick and wheel once, then never use the humidifying function again?
krazedout
Guys, this AP from Philips, worth buying to combat the haze?
http://www.philips.com.sg/c-p/AC4014_02/air-purifier
Not an expert, but CADR looks quite low for the price point. (Also 61dB at highest speed. Really loud man) Not sure what grade HEPA Philips is using but I guess should be at least 10, so probably good enough?
But this a bit bo bua. That price point can get > 350m^3/hr CADR easily.
Shutterbox
If price is <300 then still worth to buy?
Asakura
500? u can get the Sharp A50?
usually the shown CADR is at max speed, not sure if u wanna be sleeping at 61dB for just 279m3
xseanyx
Having hepa shows how much they can trap but ain't how the machine kill/destroy the virus/bacteria as important or more important?
leonaheidern
Get from this seller, excellent service and extremely responsive ALWW replies. Excellent packing, so that you do not get a flattened or HEPA with holes. :s13: Trust me, happened to me before, and TB seller is not Amazon freeship/CS.
https://shop100284682.world.taobao....a.7700846.0.0.2yXHrR&user_number_id=812256264
Tell him you want the Sharp 180 机 HEPA.
Original is 30mm. You can ALWW and tell him to customse to 35mm depth.
30mm has very slight airflow drop. But it's basically H10 -> H11.5 upgrade, so no worries.
Pay 10% more and get 35mm depth. He can customise to 45mm as well, not sure if the FU-Z31 or your model can take it or not. But don't waste the money, 35mm is sufficient. Those who are anal and have budget, then maybe go 45mm depth.
The sides, just stuff up with some plastic wrapping paper that came with the HEPA or tissue paper, prevent bypass.
You will be in good hands, the stuff works. Measured before, at outlet, in-room performance etc. No worries.
I have 2 of this Hitachi EP-A3000 Air purifier from the 2013 haze season
I think after this round I'll probably need to replace.
How do I go about asking the seller to customize one for me cause I searched 日立 (Hitachi) and could not find it in his store
There is one selling on taobao for 458 chinese yuan but I am not sure if its original , 100 bucks for something not original is a bit risky.
Link to the 458 chinese yuan filter is here.
http://world.taobao.com/item/42316390229.htm?spm=a312a.7700714.0.0.ayfteP#detail
orangeman
WRX Bro, so for the taobao HEPA this is the steps right for LG 379
1) ALWW the seller say want customise
2) dimensions: 360mm x 340mm x 43mm
3) cause one of my AP need the charcoal deodorizer
4) ALWW as for 竹炭除臭 360mm x 340mm x 2mm
5) Pay Money.
6) Install stuff the sides with cotton
We can actually use Taobao HEPA for haze period right.
Asakura
so how much ozone does the streamer technology produce?
and can we turn if off?
samsung ax40 has virus doctor(plasma ionizer) for 'killing' virus/bacteria
WussRedXLi
I just threw away the wheel. Its meant to be replaced after some time.
You can keep yours.
WussRedXLi
You need to install aliwangwang and IM him in chinese. I think he might just know some english....never tried.
Taobao tips, there is a taobao official thread part 6 or part 7.
WussRedXLi
5) Pay Money.
He can only customise these depths. 35mm 45mm and 60mm.
Yes, all other steps are correct.
WussRedXLi
The bacteria/virus copies on the droplets spread via droplet infection will be collected on the HEPA, dried out in the airflow very fast and deactivated. Some strains like MSRA may live far longer, but still no worries.
Hospital ICU HEPAs and negative pressure infectious patient isolation rooms do not have UVC. Just a handful of portable models have UVC. The irradiance power/cm2 power of UVC needs to be really high and radiating on the whole filter media, that short 4W T5 or so is not going to cut it.
That is why N95 works for viruses like HxNx with rexommendation from CDC and CIDRAP etc. You filter the droplets which are much larger.
keigo22
the taobao HEPA filter that I purchase have a Front label. I'm just wondering does it matter which direction I put the HEPA filter into my Sharp Air Purifier?
Currently I place the HEPA filter with the Front label facing the outside when I close the cover.
WussRedXLi
For the taobao hepa using PP media, no issue. Just follow the arrow and pinch tabs...else difficult to remove.
Other original manufacturer hepa are directional if they use borosilicate or PET media etc. Follow the instructions.
Asakura
is this how the bactieria/virus get stuck in vapor and caught by hepa filter?
