Air purifier?
starch1990
guys, whats the best air purifier i can get now for my small office and home?
budget @ $500 each
now targeting Sharp Fu-A80e
NWT1978
Sorry because too many pages to navigate, can someone share which air purifier is most value for money can get from like courts.
with the high demand of AP or N95 masks...stock are limited or already out of stock...
Asakura
Asakura
nothing is 'best'
there will always be something better.
check last 5 pages. at least 3-4models been mentioned.
got Sharp Samsung LG
WussRedXLi
but i heard from news...that haze going to end soon in few days time?
The DC values shown on the map are indicative values of the moisture content of a deep layer of compact organic matter. Peat soil is an example of deep compact organic soil. The DC is used to indicate the potential for fire to smoulder in peat which is the primary cause of smoke and haze in Southeast Asia. It can also be used as an indicator of difficulty in extinguishing deep burning peat fires as well as an early warning indicator of serious haze events.
RED Colour
EXTREME
- Approaching disaster-level drought conditions. Less than 5 dry days until DC reaches threshold, at which point severe haze is highly likely. Complete burning restriction should be enforced.
AS1
Got that Akira one as well. For a 40db air purifier at full power, surprising my room fan at low power is louder. Something is better then nothing.
Buckbrick
Honeywell users, may I know how loud the fan is at med speed? Using it for bedroom.
WussRedXLi
Use it in the small bedroom of a new BTO unit, should be ok.
Even the Sharp A28 medium speed is ok.
Keep the windows and doors shut properly, no issue.
Lucky177
Loud! Even at low speed, it is not quiet. Been using Honeywell APs for many years, so already get used to it. I have 2.
Effective. Workhorse. These days blasting 24x7 without any problem.
Power consumption can be higher than some APs. U may want to take note as well.
Not everyone can take the noise. I would suggest u go outlets such as Best Denki or any other local stores and listen to the noise to see if u can take it.
Can also try to search and read some WussRedXLi reviews on his recommended APs and compare.
Edit (for those who are interested):
That's how Honeywell HEPA filter looks like after using for months. Initially both outer and inner ring is white in color.
Eventually, the outer will turn black while the inner will still remain white. Of course u don't overuse it until inner ring also black. Haha.
Anyway, that's where the motor and fan will blow out the air. So, you can probably safely assume that the air been blow out is "clean".
Apart this HEPA filter, there's a prefilter to go round it, that's to capture furs, hairs, dust etc...not shown on pic.
Just sharing in case those really do not mind the noise level. Otherwise, go for other APs.
Sent from Android Mobile using GAGT
iamvarybored
den y u buy?
but i'll be glad to buy ur ax40 (if u get one) and wanna sell it after haze.:s12:
not that affected but we do get minimal dry eyes and a little dry throat, how negligible it's still a discomfort, so of course wish to at least get one to clean occasionally :D mainly and most importantly, since we can't run or work out in public, I want to clean my living room so we can do our home work outs in clean air~ can't afford to slack on fitness just because of the haze :eek:
waaa buy my AX20~~~ haha I'll be receiving it soon and I wanna sell it as soon as it reaches. I'm sure there are people who don't mind a smaller AX40 at $234? T__T (the depth is 160mm+ compared to AX40 200mm+) any tips where to sell it fast? gumtree?
but really, if I use the AX40 for only a week you don't mind to buy it?
