WussRedXLi
- Jun 15, 2001
So technically, a
310 x 281 x 400
Would have a good high airflow with minimal bypass?
Yes, will work.
So technically, a
310 x 281 x 400
Jokowi and ka kia said they need 1 more month to control it wor........
Prata from last time's 14 days dead line (made about 1 week ago LOL! )![]()
Kalimantan haze confirmed.
This haze source ranges from 600km to 1400km.
No smell, or not much smell.
We term it as "Silent Killer". Naise.
45mm
The original filter thickness including AC is about 50mm and prefilter fits, how come customize 50mm hepa not recommended?
45mm
The seller can only customise to 35, 45 and 60mm thickness.
45mm
280mm is an ok fit. It is recommended to stuff up the small gap with the plastic packaging (cut and roll etc) to prevent bypass.
Too tight a fit is not recommended. ie 282mm.
For the other dimension, 310mm is ok.
Oh, thanks for the clarification. Wasted 5mm of potential filtration.
mine already turn black after 1 week or more of using
decided to get 2 spare ones![]()
For the LG LA-Q379SB, which side of the Hepa filter should face inwards? There is a black surface (should be the nano-silver coating) on one side, and the normal beige surface on the other side). I pulled it out and forgot the direction of its facing lol. There are some korean words with arrows pointing on the top of the filter but I don't understand them. There are tabs on the black surface side. Don't know if it matters.
Do u know where can buy kcd40 hepa filter?
Thanks
I get mine customised at Taobao using WussRedXLi recommendations...
or u can called Sharp to find out the stock levels of the filters
Samsung AX40 = 31 x 28 x 4 = 3472 cm3
323m3/hr
Sharp KC840 and A40 (and probably D40) = 36 x 23.5 x 3.1 = 2622 cm3
~ 210 m3/hr
LG LA-Q379SB and PS-R459 = 34 x 36 x 3 = 3672 cm3
312 m3/hr
Midea KJ30FE-NV = 45 x 29 x 3 = 3915 cm3
~ 350 m3/hr
Novita NAP501 = 24 x 30 x 1.9 = 1368 cm3
Sharp A28 = 28 x 30.5 x 2.5 = 2135 cm3
168 m3/hr
FU-Z31/FU-Y30/KC-930 = 38 x 24.5 x 3 = 2793 cm3
180 m3/hr
1 layer only?
