Air purifier?
JoePilot
Bro WRX,
Toabao HEPA 300x300x25mm fits the AX40, with airflow reduced by 35%.
Customized ones at 45mm or 60mm improves airflow to near original or slightly better, but are more expensive. Correct bo?
JoePilot
the courier did mention it was meant for sun delivery and he is doing 1 day earlier....
I also just opened my 1 week old AX40 to vacuum the pre-filter. filter itself still looks white but the 3M Filtrete I placed just after the pre-filter turned greyish :eek:
Sounds like the 3M electrostatic filter is doing all the dirty job while the HEPA jiak liao bee.
Seriously, the exhaust side will look clean, cos all the nasties are trapped on the intake side. Intake side is only visible after u separate the charcoal filter.
Exhaust side is white, intake side is blue.
JoePilot
Had another look at the ax40 charcoal screen...I think it's way too tedious and time consuming to DIY replacement of charcoal granules. Too much time and effort for something that only lasts 1-3 months. Simpler and easier to just get a $2 activated charcoal pouch from Daiso and place it on the exhaust vanes. :o
WussRedXLi
Vivo BEST Denki still has 2pcs of white Sharp D60. 749.
Many pieces of D40. 549. Black and white all got .
Novita 001H $949. 4pcs.
Asakura
wa all selling so ex
haha can buy many ax40 to prepare for next haze
hOp3SoT
Guess who was outside my gate earlier=:p
Ordered from rakuten Thur 00:10, seller shipped same day and now received liao despite the tracking info saying only weekday delivery
So although I paid 253 without spare filter, seller was super fast in shipping out before Chuseok closure
tats really fast n lucky! :D does it comes wif a plug adapter?
LFC25
I intend to get a Honeywell AP, its spec stated 127w. Anyone knows what wattage transformer should I buy? I think I should be able to get the transformer at SL Tower.
mccmmm
Precisely,human greed we suppose to help n let heading to mass self destruction . materials used to make ,waste of extra electricity,waste of space for storage etc.
We already use aircon just put pile of water below each unit do helps
Save your mother earth pls
derazor
AX40 original Samsung HEPA is 40mm. Slice it open and its 40mm.
I have no experience with AX037.
Not sure what/how is the logic behind your " thinner depth HEPA is good." 310x280x40mm vs 310x280x45mm, the 45mm filter has more media/more surface area when the pleats are all opened up, flows more.
Customise to 45mm, that is my recommendation.
Can do 60mm too if you want, but prefilter need to DIY as original cant fit.
1pc is rmb 135. 4pcs is rmb110.
If too much trouble, suggest just get the originals.
Personal choice ba.
So just tell the TB seller the above spec and it will plug and play to the Samsung AP?
ralliart12
For the good ol' Samsung AX40, how do I know when the HEPA has outlived its effectiveness?
WussRedXLi
bro wuss 911, I've been reading since pg 32x but can't find the spec for the Samsung A40. Need help lol. Total how many pc to order ah?
Buy 2pcs for this haze period if you can help it.
It wont spoil one, can use very long. Replacement filter get from taobao.
WussRedXLi
When you cannot tahan the smelly air coming from the output.
Approx 6 months can change. Or time it 8 months non hazy and 4 months hazy change cycle.
Akai Ryu
pls recycle your used hepa filters and not contribute to incineration or landfills
ralliart12
I can offer 淘宝 expertise to those who are not familiar with the process (chatting via 阿里旺旺, forwarding, etc).
I'm also trying to get some spare filters for my Samsung AX40. What I lack is the right merchandise link & the specific spec to tell him. Anybody who can share this information I can order a few for you (no monetary profit). Self-collect at Tanjong Pagar station during lunch time on weekdays.
In terms of shipment optimization, with air shipment not much optimization. Unless you ordering enough to exceed 10kg for air shipment, or enough purifiers to clock 1 cubic metre (at which point can consider sea shipment which will take close to 1 mth to reach SG).
Just let me know the details.
imacbie
shop is here, https://goo.gl/8fD90h
i think he knock off already .. not replying to my msg
