Air purifier?
kyuushin
have been silently lurking in this thread after finally seeing it.
Bought a local Honeywell 18200 about 2 weeks back and ordered the Samsung AX40 after reading all good sharing
Many many thanks for all the information posted! :D
derazor
I can offer 淘宝 expertise to those who are not familiar with the process (chatting via 阿里旺旺, forwarding, etc).
I'm also trying to get some spare filters for my Samsung AX40. What I lack is the right merchandise link & the specific spec to tell him. Anybody who can share this information I can order a few for you (no monetary profit). Self-collect at Tanjong Pagar station during lunch time on weekdays.
In terms of shipment optimization, with air shipment not much optimization. Unless you ordering enough to exceed 10kg for air shipment, or enough purifiers to clock 1 cubic metre (at which point can consider sea shipment which will take close to 1 mth to reach SG).
Just let me know the details.
I pm you tonight
otacon
I m ordering AX40, if u getting filters from taobao, pls help me order n also pass me the specifications in case I can't find u in future, I can order myself. Do let me know how much so I know how many pieces to order. Thanks
Sent from iPhone 7 using GAGT
ralliart12
I pm you tonight
Don't really need to PM. If you know the specs, just post here. Next time newbie like me search also will stumble upon the useful details (now I'm back-tracking through the thread to sieve out the details). Anyways:
I also waiting for response.
iamnagel
Please help me order 4 pieces if you are going ahead with the order. Thanks in advance. :)
Sent from LGE LG-V500 using GAGT
Asakura
RMB110 ea for 310mm x 281mm x 45mm HEPA. Gives about 15kph windspeed at the outlet. Need to aliwangwang and chat with the seller to give the dimensions, but he knows what to do lah....coz have sold a few liao.
This is just a link to the seller's shop....not for the item.
http://item.taobao.com/item.htm?spm=a1z09.2.9.162.ZaWosI&id=20676620186&_u=t1u0hcib32b0
The RMB26 HEPA also can be cut to fit the Samsung AX40. But airflow is 12.5kph. Good enough for daily use.
Wattage when using the RMB26 HEPA is 19W for the AX40. Wattage when using the RMB110 45mm depth HEPA is about 27W. Measured by a DMM at the power socket. So it's maciam like a manual fan speed control. :D
And no matter what, be it Sharp original HEPA or customised taobao HEPA or your own specially cut up HEPA, all must use the plastic packaging/tissue paper and roll them up, stuff them in with a ruler/flat blade screw driver, plug up the sides to prevent bypass. They will work ok as long as , don't worry, I have measured many times.
chuanz
k i reuse old hepa on my other ap that i abuse, then its in the recycling bin...hepa = paper
Actually, isn't HEPA more like plastic category...? PP/PET
High end HEPA uses like borosilicate fibreglass...
Starushz
Can the virus doctor in ax40h5000gmd be switched off? The AP seems value for money but i dont trust those ioniser.. if it produces ozone then its no good. Like sitting next to a photocopier..bad for lungs
chuanz
Default is off and yes can be switched on/off.
