Air purifier?
Mach3.2
wongminmin
one thing is don't really trust taobao seller.
dilemma between Amazon and Tabao.
But if buy from taobao.
AX40 Filter (specially customized for SG, buy 4 got discount): http://world.taobao.com/item/522668837488.htm?spm=a312a.7700714.0.0.d4JaZN#detail
Sharp A28E (Stock - 310*285*25) they sell 365*277*25, so just trim abit
https://item.taobao.com/item.htm?spm=a1z0d.6639537.1997196601.14.7IhuYI&id=38909741084
i also skeptical in buying from tb since i know they do produce fake hepa filter for their clean room.Just buy and test loh since so cheap.
You save about $15 if u purchase 4. You can try to group buy since there are so many ax40 users here.
Froggyman
:eek: You didn't use the SEMAIR10 code?
Hi guys,
Need some help.
Have try to enter the code : SEMAIR10
but when next page .. it will ask me to enter an valid code.
Can tell if i type the code wrong or need to do something else.
Thanks.
ralliart12
The AX40-compatible HEPA filters I purchased from TaoBao worked out to be SGD$38.24 per piece.
nwh_sg
Thanks for confirming! :)
Just saw a pic posted by WRX, I believed that is the local PS-R459. In place of the NPI function indicator is the Brightness control indicator on the LG LA-Q379 (you can turn off the LED totally). :)
h0bbes
Anyone can help?
Thanks
Are you at the payment page where you enter your CC details? That's where I input the code. It's at the bottom after the CC details. After you click 'apply', the summary at the right should reflect the discounted amount.
BuShuang
Hi guys,
Need some help.
Thanks.
Used the code on the account before? If yes, use a new account.
Did u log in via shopback? Code doesn't work with shopback.
Froggyman
Yes, everything is OK until i click the place order button.
After clicking the place order button, the next screen appear
" Please enter a valid coupon code and try again."
try a few time .. same issue :(
Or do i need to do something to get that coupon first ?
Thanks.
Froggyman
First time using it with a new created account.
Log in thru rakutan webby.
using SCB mahattan card .. any issue?
thanks
update :
Set up a new account again as your suggestion.
OK. No problem with the code.
Thank alot
linusz
Bookmarked. Thanks
WussRedXLi;8413 8165 said:
For those in dire need of filtration and due to medical conditions require "anything" but have little budget....can go for this for your air-con.
mediawebserver
Still available from HomeFix, some NTUCs and the likes. Not expensive, it's S$17.90. (Amazon selling same size @ usd4.95 last year).
Fix it up on your air-con, or box fan if you do not have a/c. At least it'd work. Proven to work last year by someone with an air particle counter. (think dropped nearly 50%). So maybe 200 become 100?
