Air purifier?
deathman91
Wash liao most likely will degrade the effectiveness...
Dunno WRX bro test before boh but so far people replace filters de. :vjayadmin:
Then again, majority isn't always right. :s22:
Don't even know if my AP is effective. :s22: Now open door wide wide also shows WHITE LED(BEST AIR QUALITY)
hanalexu
Low cost way to dehumidify
I just bought the Sharp KC-A50E air purifier and I saw the humidity indicator at 80. I'm looking for cheap ways to lower humidity level in my room from 80 to say maybe around 50-60.
Heard from my friend that maybe lowering the room temperature will also lower humidity. I am not allowed to install aircon to the place I stay, and I do not want to buy a dehumidifier due to the high power consumption (saw a Novita model using 180w).
So, I'm thinking if I add cold water or even ice cubes into the water tank of my air purifier and let it emit cool air,
1) will it resulting in a lower room temperature?
2) if yes, will it also result in lower room humidity?
3) will it damage the air purifier of the filters inside?
NWT1978
one thing is don't really trust taobao seller.
dilemma between Amazon and Tabao.
But if buy from taobao.
AX40 Filter (specially customized for SG, buy 4 got discount): http://world.taobao.com/item/522668837488.htm?spm=a312a.7700714.0.0.d4JaZN#detail
Sharp A28E (Stock - 310*285*25) they sell 365*277*25, so just trim abit
https://item.taobao.com/item.htm?spm=a1z0d.6639537.1997196601.14.7IhuYI&id=38909741084
then u can get original ones at their Authorised centre. Can call to find out stock and reserve filters. Can request delivery too.
Samsung ones just order from Qoo...
There u be assured and happy =:p
bebebbe
PS. Extreme right = live and neutral. Middle cable red white blue is to the motor (control wire also I guess or something). Right socket grey cable is to the touch panel controls.
Hi WussRedXLi,
I'm going to order from Qo10 today. Need your help on two simple questions, as you owned both LG Q379SB/P459WN and Samsung AX40.
1) On high fan, which one blows more air? Which one is quieter?
And what about low fan?
2) For the LG Korean model, is there an hidden option to turn off the ionizer?
Thanks!
NWT1978
just get those moisture absorber from Watson brand... It cheap. Sometimes it offer buy 1 free 1...
chuanz
Sharp KC-A50E
Plasmacluster Air purifiers with Humidifying functions
Water = increase humidity
Cooling the room to remove humidity only works for AIRCON.
kimsim
Suspended
Should you turn on high fan or your room slighly big, the humidity will be auto adjusted at around 70-50, just depend the times.
If your room indicated at around 80 that meant your room humidity too dry already.
WussRedXLi
For the LG washable HEPA, I guess there is no hard trying to wash. But in reality, you cannot wash it with a brush and it's not going to be effective since the PM is trapped way inside. You just use your shower and try to rinse it out. And not much PM would be rinsed out, coz you must remember that even high fan speed blowing through the filter won't dislodge the very very fine particles, such is the nature of HEPA media.
It's probably just a marketing gimmick that works mediocre at best, for 1 wash only. (not to say that it would not work). And probably the HEPA integrity would be slightly compromised after that, though still in a workable state.
The LG HEPA is physically constructed such that externally it is tougher than usually with an additional protective netting layer so that it wraps the actual HEPA media/fibres inside securely.
Just replace it, don't get a headache over it.
Other HEPAs, pls do not try to wash it. People have washed it and destroyed it.
kimsim
Suspended
Fr your personal review LG vs Samsung which one more efficient and effectively?
Asakura
there are videos n pic on people opening up their used filters
if u are replacing ur filters soon, u can open urs up as well.
u can understand from there why it should not be washed.
and for those marketed as washable, u are not directly washing/scrubbing at the hepa filter otherwise u would have damaged it.
makav31i
Took a leap of faith and bought the SK Air Cube SN-100C to help me monitor the air at my home...
ralliart12
Just curious: is "PSI" a pollutant or an index? Because I was browsing the AQICN site & somewhere there it says, "primary pollutant: PSI"...
