Air purifier?
Asakura
lol no lah
using this now but until my 2nd set come I need to move from room to room, somtime my son will move also. laycher to use this plug and scared for them.
:s13:
my extension is tis kind
chuanz
Actually we could just get and change to our 3pin 13A plug which cost about $2 each and don't need the hassle of having to move the multi adaptor along with the AP if we need to move the AP. But any problem if we change to the local 13A plug, anyone tried?
Moi. I got one AX40 cut and replace to 3-pin.
And no, 16A is not specified by manufacturer. It's the max current the plug/wiring standard is rated for. Just like our local BS1363 standard is rated for 13A.
Samsung AX40 designed for 220V @ 34W ~ designed to draw 0.16A
(SG is 230V, but that's not gonna raise your current drawn by one magnitude or two)
Edit: mod at your own risk, and only if you know what you're doing.
eurofunk
just made the order for one ax40 as backup since noticed the price dropped back to 300 heh (was 320+ few days back)
spidey19
The daily plane to Singapore from Inchon is in the wee hours, if heng maybe they sort finish early and push it out for delivery, else most likely on Tuesday since they have to clear packages of higher service tier on Monday.
I think will make detour, mine travel from Korea to Guangzhou, now stuck at Narita, Japan...
I think can't reach by 6pm as stated
wolfverine88
The status for mine has been “Left FedEx origin facility” since noon of 1 Oct. No further updates since…
Ximple
Just bought an adaptor plug for AX40 for S$1.70 from Japan Home.
