Air purifier?
eurofunk
ok so thicknesses is customised but the size isn't it fixed? Too big cannot put inside the ax40 isn't it
NWT1978
Hi the seller had replied.
30 pieces :s12: how come no free gifts nor cheaper?
kimsim
Suspended
So this one is which filter for the ax40 how come so cheap 120rmb....
480/4 = 120 RMB should be ok, still not inclusive forwarder shipment to sg, more than $400 have to separate older and shipment as well, otherwise added GST to be different story
BigBlueBox
The status for mine has been “Left FedEx origin facility” since noon of 1 Oct. No further updates since…
I think my order is in the same shipment as yours.
Called FedEx and was told that the domestic flight was delayed due to bad weather.
So item now still stuck in Korea. It will need to fly to China before coming to Singapore.
idiots
kimsim, my 2x order although from same seller for Samsung ax40,need to alww with seller 1 for customization. Dimensions are 370mm x 234mm x 45 mm. Please take note. Will send you email later tonight.
AngPao
Bro Kimsim,
I just received my filters. Fyi, 7 pcs of filters will cost 163 rmb (around 5.7kg)
Try ask seller send in one box else 4px will not send other box(es) as no TB order nos attached.
AngPao
Take note and reminder: AX40 filter custom make 45mm thinkness is not able to put charcoal filter.
kimsim
Suspended
Bro Kimsim,
Customise won't be happen on 4px in separately box, unless you bought 4pcs only
laeticia
Just giving caution, not being jek ark, as based on picture, dont look too stable as top heavy and also not too sure on the 'smoothness' of the castors.
thanks for your concern, was at Daiso earlier and bought a non-slip mat to place on top of the stool. it seems stable enough and its mostly to adjust the position of the AP while I'm in bed since I use it like a fan as well
previously i had the AP sitting on a footstool
kimsim
Suspended
Your size will pending for before we purchase at same time.
Usually 1mm different they will made it in round figure.
xyz2006
i. I got quotation from the diff price of HEPA复合网 and 單HEPA price. May I know what is the diff ?
