derazor
- May 19, 2011
So mafan in the end it still seems to get the additional original filter at $70 is best liao
Local original is $70??????
If really 4pcs at 2.7kg that's sound good..will reduce the shipping cost
Thanks for your input
Anyone can recommend a cheap particle counter to buy from taobao?
The amazon ones are really exp to bring in.
Just get the Samo Air. Or that cute little one with 2.4" TFT screen at 239 rmb.
PM2.5 激光
my a/c has got hepa filter installed (i think its a Sanyo inverter unit).
do you think these hepa filters can replace the ones used in a/c, assuming dimensions are close?
i don't have the dimensions now though
These 2 is it?
These 2 is it?
Samo Air
samoair超越Dylos专业0.3微米六通道 激光粒子计数器pm2.5检测仪
激光PM2.5检测仪 B4 激光PM2.5传感器 A3 空气质量检测仪 益杉
These 2 is it?
Samo Air
哇, really no kidding about the cute part; but most importantly, is the sensor really decent...
WussRedXLi, can you confirm if the link in my previous post http://forums.hardwarezone.com.sg/97071368-post7746.html for 2 particle laser counters are correct? If correct then I add to my page. Later link salah and ppl buy that I![]()
Sigh, now I know why the feedback for direct international shipping from TB is so bad. Totally no updating of tracking, and no way to ALWW anybody to ask
Should have stuck with 4PX
More reliable
Now still unsure that hepa how many weight per piece yet.
I use 4PS is air shipping.
If the weight lesser so the overall cost is lower as well
More reliable
@Kimsim,
FYI, I bought total 8 pcs (4x A40, 2x Sharp A80 and 2x Sharp A28) from the same seller as u. 4PX charge me 163RMB (weight 6kg).
Hope this help u too.
so many bad comments and u still use it?![]()
