Air purifier?
Asakura
Just think long term.
If one can tahan the specs of Honeywell, they are workhorses.
If one can tahan the noise/power consumption of Austin and replacement filter cost, they are workhorses. (no real mention of this brand in this thread). Their AC and Aluminum oxide + KMnO4 mix is crazy, some 5kg for the bigger Healthmate series?
IQAir is up there but too expensive. Similar for other usual suspects.
Sharp brand is going downhill, but the APs are workhorses. There are 10 years old AP still working.
Samsung/LG are new to the block, I hate their aircon and refrigeration products. But APs are great. For regular folks like me who want to have 2-3 rooms regular day usage + provide filtration at parents place coz they are also the caregiver during daytime, then a price:performance ratio over the long term is crucial. Throw in Super El nino 2015 haze season, where you might wanna filter 2 x whole HDBs, it becomes crucial, including filter replacement costs.
If one room, then the decision is usually much easier.
i remember austin was mentioned in '13 or '14
the weight of iqair puts me off. and after i see the video of how they remove the filters in the iqair i don't really wan it anymore. it looks bulk and very hard to remove :s13:
but damn the filters inside looks really good, of cos there's a price to pay. one replacement is the price of 1-2AP
they should each last around 2yrs iirc
i need multiple AP for my house, so 1 monster like iqair(heavy to move around) or coway is not to my liking..
linusz
Honeywell are energy suckers?
vofzxy
The AX40 is really small hahaha
Sent from LGE LG-H815 using GAGT
kyuushin
You can't "see" which grade unless they tell you.
https://en.wikipedia.org/wiki/HEPA
Either email manufacturer or try your Google-fu.
Yes, calculate the ACH most zhun, don't bother with the "recommended room size"
Manufacturer website or from manual that comes in the box. Or based on other people testing.
Thanks so much bro chuanz for answering. Guess I've alot of reading and google-fu to do to catch up knowledge on this area
Thanks for sharing knowledge for laymen like me to learn from too
linusz
My last Tuesday ordered ap from Rakuten will only be here tomorrow. Anyone same?
alantcy
Was considering between the Xiaomi and Samsung Ax40, decided to go with the latter (ie. lower operating noise, ion generator, filter availability)
vofzxy
Look folks.....I have posted like hundreds of posts in all the threads. It is impossible for me to provide evidence to prove things over again and again and again.
When I share data and recommend products, there is a real reason(s) behind it.
Thank you.
it's getting hard to keep up hahaha =(
Akai Ryu
feel like buying some silver and put in the water tank of my humidifier ap
kimsim
Suspended
Finally just done my simply store for you guy who needs pre-order and key in your detail here.
http://kimfilters.weebly.com/
Anyway for samsung hepa custom size would be pending only, except the rest is final already.
Thanks for your support. :D
john hanley
I'm thinking of getting a 3m 7501 half face respirator or full face respirator like ff-400....air+masks L sized and Active ventilators all out of stock......
3M mask comfy, reusable and P100....seems more bang for buck. :(
