Air purifier?
makav31i
can u ss the co2 reader? how is the app interface? must position cube in certain manner? as in display face front or up? tia
I put it facing up, not sure if that is the proper way to display it...
Akai Ryu
Thanks! u ordered fr goni? noticed no colour choice....what's yours? Does it auto shut off when disconnect fr BT?..had been beoing this for awhile but was waiting for some review here.
makav31i
Mine is the gold color...Not complaining about it as I like the gold color...Yes, I bought it from Goni...not really sure as I off it manually...later weekend will do a full review..
LFC25
same here. wondering if DI or CO2 useful.
Nintendou
The air cube does not shut down when disconnected from bluetooth. Battery life is about 24hrs according to their specs.
Readings can be set to be taken at 15s, 30s or 1min intervals. The readings will be uploaded when you connect again via Bluetooth. The app can display a graph with the readings plotted at hourly intervals. There are graphs for weekly and monthly monitoring as well.
It will beep when co2 or fine dust particles is too high. Connecting to Bluetooth will also beep (like bomb going off). The sound can be turned off, according to the manual.
Doesn't state anywhere what is the type of sensor used.
CO2 edition does display the Discomfort index in the app, but no indicators on the air cube.
cyberian07
The $1.70 Powerpac brand multi adapter from Japan Home is ok because the 2-pin plug fits good and is not loose unlike the no brand ones I have.
Maybe it is because it's new so the fit is good :o
Hi acidz. Would u (or anyone) mind posting a picture of this adaptor from Japan Home? I know some had posted some pics of adaptors. But i just want to be doubly sure. I bought the wrong adaptor and my AX40 just sat beautifully in my bedroom *sign* I'm a very clueless lady 😛 thank q so much.
P/S: in case u're wondering, I bought the (wrong) adaptor b4 I viewed those pics cos I thot how difficult can it be...
mindgamey
Wanna purchase ax40
Hesitating any advice
Goniglobal 239 free mask
Please dont buy from Goni.
Buy from happy mall.
A lot of people having issue with Goni.
I am seeking refund for my Air cube, a screw up by Goni and bumbox.
