Air purifier?
WussRedXLi
Is there anything that purify and add humidity at the same time?
Sharp models and quite a few others got models that do that.
But the humidification rate is not say very fast.
Seriously air-con is not that drying if you do not set it below 25 deg C.
WussRedXLi
$44.94 get from Sharp authorised parts centre @ Alexandra Technopark Tower B. Call or email them to check if got ready stock or need to pre-order.
Quite ex. Does anyone know what is the depth of the filter?
http://www.amazon.ca/Sharp-FZ-A28HFU-Replacement-Filter-FZA28HFU/dp/B0085FBHH2/
Seems like it is about 28 by 31cm.
See which filter that you can get from Amazon and cut it out.
The filter is a E10 or "HEPA-10" filter that's 85% efficient. That's like a 99.97% H13 filter with 15% airflow bypass. :)
Or put it this way. 168m^3/hr airflow. 144m^3/hr clean airflow, 25m^3/hr dirty unfiltered airflow.
So any H13 filter that you can just cramp into that space even without PU foam or scotchtape is still going to work better.
mosmos
High Honorary Member
novita with free extra filters sgd269 + further sgd20 discount (using sgd10 coupon + 1000 Qpoints when click on that PIC in their website)
link: list.qoo10.sg/item/NOVITA-FREE-FILTER-PACK-NOVITA-AIR-PURIFIER/415907163?sid=750
Asakura
anyway for those interested in iqair, these are the estimated filter change frequency
Pre-filter is 12-18 mths $160.50
Carbon filter 15-21 mths $256.80
Hyper HEPA is 36 - 48mths $374.50
WussRedXLi
Who ever knows that buying air purifier can be addictive huh... :s13:
Still don't know how serious and for how long the dry period for this region will be. If it's serious, no amount of govt (SG and ID) intervention would help.
If really serious, i may hoot another AX40 via FedEx....hope then still got stock. :D
InnovaIQ
bro.............mai ** leh....................moi wan u............lompan moi filter paper............................u eh eh or or....................wow lan eh...............
WussRedXLi
My buying habits from Amazon very difficult to predict one leh.
You can try touchme kor kor from AMZ free ship thread, collect from Suntec?
mosmos
Novita has one model that can do both
Have one and so far so good
Don't need to switch on humidifier if don't need
After you browse some pages behind in this thread, those air purifier with humidifier, their filters after sometime became mouldy and maybe spraying moulds instead of clean air~ :(
