WussRedXLi
- Jun 15, 2001
Make Your Own Air Purifier For 200 RMB? Really? Really. » MyHealth Beijing
So yes, it makes perfect sense that a do-it-yourself combo could work — and it does. I tested the smaller Original model in my three small rooms, 10-13 square meters in size, overnight with the doors closed. And this little guy did about as well as any other machine I’ve tested: PM1 levels were 91% lower than the outdoor air, and PM5 levels were 95% better. This was on its lowest speed setting, which was tolerably loud but certainly noisier than my usual Blueair settings at night. In my most recent testing of Blueair, IQAir and Airgle, I got bedroom results of 88-90%. For small rooms, this little HEPA filter was at least as efficient as all of the big boys.
His newer machine, the 450 RMB Cannon, was designed for bigger rooms, and I think that also could work well in theory, since it’s the same HEPA filter on a stronger fan. I wish I could share hard data with you, but honestly I didn’t get a lot of data points on this machine, mostly because it was just so darn noisy that I didn’t want to test it any more in my living room. Even at the lowest setting overnight, it was much louder than normal background decibels from my current IQAirs. For me at least, that’s a non-starter as an option. Thomas openly admits that the Cannon is a bit loud, but it still is effective even on low settings (see the graphic to the right).
Time sale.
