anthonygreenisreal
- Oct 2, 2014
this is another league from the Sony XM4. But from practical point of view the XM4 has enough to wow most people.
i think you can find it at below $849 now. $6xx range can easily find on legit sources like Lazmall on lazada. Yes sound stage is different. its very hard to describe in words. You probably need to go and hear it yourself to decide for yourself which do you want. go to 313 at sony to listen to it... then go opposite to apple store at orchard and listen to the apm.Is APM worth the price tag? The XM4 cost $399 but the APM cost $849. So sound stage wise so huge difference? I heard APM is heavy and also you cannot power off. Any issue with that?
Any recommendations on lazada? Which legit source selling at $600+? Love to buy 1 and try. Ppl trying to pass used ones as new on carousell all selling $700 etci think you can find it at below $849 now. $6xx range can easily find on legit sources like Lazmall on lazada. Yes sound stage is different. its very hard to describe in words. You probably need to go and hear it yourself to decide for yourself which do you want. go to 313 at sony to listen to it... then go opposite to apple store at orchard and listen to the apm.
No issue with not having a button to power off the apm. I'm not even using the ugly case. Im putting it on the charger since i am not bringing it out. when not in use plug in to charger. will always have charge. The power management is better already after the latest firmware update.
The APM is very convenient to switch multiple apple devices. I watch movies on the Apple TV and listen to Apple music via the APM when its late at night where everyone else is sleeping. And i take teleconferencing via the APM too.
I use the xm4 when im playing ps4 by hooking it up to the controller. Dont need to power on the headphones. (which is a good thing)
i bring out the xm4 when im commuting.
Your use case may be different.
Apple’s flagship store on lazada. Wait for the sales. Now its about $700+ . Note that you cant return it ya… Apple store policies dont apply on the lazada ones unless u buy direct from Apple.Any recommendations on lazada? Which legit source selling at $600+? Love to buy 1 and try. Ppl trying to pass used ones as new on carousell all selling $700 etc
You can also get from Qoo10 Korean stock with local warranty for less than $600 ex GST.Any recommendations on lazada? Which legit source selling at $600+? Love to buy 1 and try. Ppl trying to pass used ones as new on carousell all selling $700 etc
Hi AdiboyYou can also get from Qoo10 Korean stock with local warranty for less than $600 ex GST.
Now no promo so the price is on the high side.Hi Adiboy
Can share the link please?
Thanks Adiboy. Will keep a lookout. Wonder how these ppl sell so cheap. Haha! Even cheaper than those 2nd handNow no promo so the price is on the high side.
If there is promo, the price can go below $600.
https://qoo.tn/BiGMlX/Q133786156
I'm using belkin. $5 cheaper than original apple ones from apple store.Anyone found a 3rd party lightning to 3.5mm for AirPods Max?
Do you have a link to that particular cable and where can I buy? Thanks!I'm using belkin. $5 cheaper than original apple ones from apple store.
Thanks! Base on what you describe connecting AirPods max to PS5 controller that is exactly what I want.https://www.apple.com/sg/shop/product/HM792ZM/A/belkin-35mm-audio-cable-with-lightning-connector
not sure if this is the one you want though, im using this to connect my airpods max to my ps5 dualsense controller. sound is quite clear.
funny thing is the website explicitly states that the cable does not work with AirPods max. Very confusing![]()
Heh thanks for the info.Now no promo so the price is on the high side.
Was waiting for the next iteration, oh well.Sadly no USB-C variation this time round![]()
