AirPods, now available.
Gambler.
bought the airpod silicon/rubber tips from taobao to try and improve the fit.
i realise it helps slightly, but i still can't run with my airpods as it just slips off after.
guess the fit just doesn't suit my ears
parkson
Which one did you buy, I bought the earhooks from Lazada and it fits perfectly now. Able to go running with it.
auzzuro
whenever i switch from my iphone to my ipad i need to go setting ,bluetooth to connect it .anyway to solve it ? my iphone n ipad both hv the same apple id .. but still need to go setting to connect it . so troublesome
deathst
You can actually just airplay it. Assuming you used it on your iPhone and now you want to use it on your iPad. Put on the Airpods.
On your iPad, Open Control Center.
Press deeply or touch and hold the audio card in the upper-right corner of Control Center to control audio.
Tap the Airplay icon, then choose the device you want from the list.1
jq75
Did u buy those with hooks?
