Amazon eero Wireless Devices: Master Thread
Quick summaries of the eero WiFi 7 router options available in Singapore.
Just to check the new eero pro 7 from eight is 5 gbps or 10gbps port and what is the difference between this and max 7?
eero Pro 7 10G: dual 10Gbe ports, triband WiFi 7 BE10800
https://support.myrepublic.net/en/articles/15896549-eero-pro-7-10gbps
eero Max 7: dual 10Gbe ports and dual 2.5Gbe ports, triband WiFi 7 BE20800
eero Pro 7: dual 5Gbe ports, triband WiFi 7 BE10800
eero 7: dual 2.5Gbe ports, dual band WiFi 7 BE5000
Quite a few ISPs used to offer eero Max 7 including eight home internet. Now I tend to think they may not offer that option any time soon.
Any chance to get max 7 from eight or any telco again?
I believe not any time soon.
Jun Jun
Yes, they do. Check eero's release notes. For example, they introduced 802.11k and 802.11v support in October, 2021. They started supporting 802.11r in June, 2017.
No single vendor controls wireless clients. You have to support at least 802.11r if you want wireless clients to hop from radio to radio more quickly. (802.11k and 802.11v are less important, and some clients don't support those protocols.)
The OpenWrt community consensus is that 802.11r is the most important protocol for roaming, and I think I agree with that. I've never seen 802.11k/v supported without 802.11r, but maybe I haven't looked hard enough.
802.11s is an attempt to get some multi-vendor standardization, but it doesn't seem to have caught on.☹️
That's really a different thing, albeit related. You can have a wireless network with 802.11r/k/v — with some protocol such as 802.11s providing coordination between access points — and still manually tweak aspects of your network (channel widths, transmission power outputs, channel selections including possible DFS channel rescans and resets, etc.) I do that, actually. Eero devices specifically won't let you do that. They try to optimize for the local environment automatically and don't include many manual overrides.
Yes, absolutely. With wired backhauls if at all possible. (Use MoCA 2.5 adapters if you have coax ports and don't want to run new wires.)
I suppose a notable exception is OpenWrt. That is, it's the firmware that matters, not the actual manufacturer of the device itself. And I suppose MikroTik's RouterOS is another exception since it can run on some non-MikroTik equipment such as a mini PC.
Does archer be900 easymesh supports kvr?
BBCWatcher
Amazon.com (U.S.) is currently selling brand new eero 6 wireless routers for US$54.99 each. The eero 6 will currently receive security updates through at least October 31, 2031. Amazon has repeatedly been pushing this date out as it continues to sell new units. (Amazon promises security updates for at least 5 years after last new retail sale.)
BBCWatcher
Amazon has pushed out the dates again for the end of security updates for all eero 6, 6E, and 7 devices (except the eero Pro 6) to December 31, 2031.
The December 31, 2031, date should be viewed as a minimum, not a maximum. Amazon promises to support each eero model for at least 5 years after last new retail sale of that model from Amazon. The published dates are periodically pushed out consistent with their +5 year security assurance.
