Gixxerfied
- May 24, 2008
delta or anaYou need to specify which airline do you have intention to fly with.
I need a bigger spoon!
My advise is avoid delta..the service & food compared to ANA is cmi![]()
my food on delta sin-nrt...
jal/ana have much better food![]()
wakao damn cui. heng i book ana![]()
in comparison, this is jal's sin-hnd
http://i.imgur.com/DxBAStB.jpg[img][/QUOTE]
Jal same price for nrt sector compared to ana for the period I'm looking at thou..
hihi so for ANA is 2 x 23KG, I must make sure each baggage doesn't exceed 23kg or I can combine both to be 46kg regardless each of the baggage weight?
You can check in 2 luggage, each should be max 23KG, anything more then extra charge..
Linear dimension of luggage at max 158cm..Cannot exceed 158cm if not kena...
You cannot have like 1 x 30kg and another mayb 15kg(Still falls within 2 x 23kg = 46kg)..
are they v strict with the dimensions?You can check in 2 luggage, each should be max 23KG, anything more then extra charge..
Wah thanks! Sounds damn sian sia. lols. I will try to do make it weigh exactly!![]()
They never check in my case - 29" linear dimensions add up to 158 +/-. Maybe those 32" ones v obvious they might check.
