- Sep 16, 2018
How is T9 Tv box, any reviews?.
Do not buy this type of boxes from unknown vendors.
any TV box to recommend?
Sent from the jungle using GAGT
Any recommendations on where can I buy Mi box? I went Mi Shop at Suntec, they don't even have it in the shop. Thanks!
Posted from PCWX using SM-G975F
Mi box S has only 2GB RAM, will that be sufficient, will it not hang.
1.5 GB is more than enough
buy from taobao sua
https://www.lazada.sg/products/xiao...chromecast-netflix-i282639019-s448775403.htmlbuy from taobao sua
Updated my previous gen mibox International to latest oreo update. No issues even using a cheapo $4 USB 2.0 to Ethernet adapter for lan connection instead of wifianyone updated their xiaomi tv box to the latest android ?
I don't have a suckhub go account but if you installed it on your mibox why do you still need the casting featureI am using Mibox S to watch shows via Starhub Go app. Last week I was prompted to update the app on my phone and now the casting don’t work again![]()
In the android tv play storeHow come can't find the tvbanywhere tv app anymore? Is it removed?
Sent from Xiaomi MI MAX 3 using GAGT
Is starhub go even compatible with android tv os? It crashes on my mibox InternationalI am using Mibox S to watch shows via Starhub Go app. Last week I was prompted to update the app on my phone and now the casting don’t work again![]()
