candy crush
- Sep 2, 2019
can recommend apps for the Taiwan channels ? paid or free ok. 4gTV has some free Taiwan channels but they don't play well on my android TV.
Go google Tangyuan
Guys got a question
My Android T9 android box unable to detect my wifi in my own house
but can detect other router/wifi (neighbour one), sometime can detect my wifi, but non 5GHZ, sometimes I have to restart my router
Today I restart my router many times but I cannot find anything
how come uh?
I am using Starhub Linksys
if you can detect the router using mobile, then means router ok.
Can take the box to another house and try search wifi, probably can’t work.
Try upgrade or reset your box and see, it’s the box problem。
But it can detect my neighbour wifi leh
Thanks later I reset
go to router's admin page and set the 5GHz wifi channel to manual - channel 36 or 40. you will have problem if it is set to auto.
Go google Tangyuan
Tangyuan also available in supermarket![]()
Can someone recommend a box that can support Netflix( at HD/ 4K HD), MeWatch, Singtel Cast and Sports IPTV ?
Browse through the last few 20 pages got saw a few ppl recommending A95X F3 Air 8K RGB Light TV Box Android 9.0 ? Is this hassle free and ease of use ?
Get A95X F3... Is a good box than mi box and cheaper... price is half of mibox and with better spec....
And it can get all the requirement u want... Mibox is branding but a lousy box... the specs cmi...
Get a95x f3... cheap and better spec than mi box... highly recommened... and the best thing it has a root toggle switch... U can install any app u want... including singtel tv go...
Interesting to know that SingTel TV Go works. What about SingTel Cast?
for amlogic, there is easier way to flash, just copy the firmware to thumbdrive, add a small text file to define parameters, plug in and power on then the update will perform by itself.
How does this work? Any guide on how go set the parameters? Try to do something to all the old and useless 805 boxes my parents accumulated in the past few years.
diff boxes use diff confi files.
if you have many 805 boxes, it is easier to use USB cable and usb burning tool on PC.
By the way, it is not necessary to flash firmware for most cases, just factory reset will do.
if these boxes have only 1GB RAM, go to this fb group to find out how to remove the lagging problem.
https://www.facebook.com/groups/1gbramTvBox/
