- Sep 16, 2018
What is a good recommendation for a Nvidia Shield Killer?
Sent from OnePlus ONEPLUS A6010 using GAGT
None for now.
On the other hand, depending on your needs, Mi Box S may be good enough for most of the people.
And there are alternative box like the HiMedia S500 or probably the Mi TV Stick 4K which will be good upgrade for Mi Box S, if you need Netflix HD.
If you do not need Netflix HD, then boxes like Minix Neo T5 and Mecool KM1 are not bad running official Android TV OS (but not Netflix certified).
Amazon FireTV Cube 2nd generation is also a powerful box with Netflix 4K, but no Chromecast. Same for the lower end Amazon FireTV Stick 4K.
So in the end, there are no killers of Nvidia Shield TV, since the first release in 2015. But then there are many choices depending on your needs.
