ubox more costly. i have use ubox for 7 years still running like new.hi all, wanted to get a tv box but has no idea which to get.
any recommendation? like ubox or evpad? thanks !
install emotn store. then enter 202096.
type on Google and u will find it...sorry what is emotn store and where to find it?
Read HWZ Forum Rules!
thanks. just downloaded and installed. doesn't seem to offer much or am I missing something??
both are expensive and illegal.hi all, wanted to get a tv box but has no idea which to get.
hi brosGotten the Mecool box, its indeed good, what tools do you guys use for maintenance? Ram Cleaner?
android tv os has very good in-built memory management, don't have to run any ram cleaner.Gotten the Mecool box, its indeed good, what tools do you guys use for maintenance? Ram Cleaner?
thank you for sharing thisinstall emotn store. then enter 202096.
i nv done it before but u cannot go dl the viu apk and then installing it manually to your android box?Anyone knows which android box can actually play tv shows from Viu?
Someone told me the ott box apparently can but only works on tablet???
Even if you install Viu, the Viu player also cannot play any video because Viu sets a lot of restrictions.i nv done it before but u cannot go dl the viu apk and then installing it manually to your android box?
if your box is running android TV OS, such as 'mibox s', the easiest way is to run viu on handphone and chromecast the video to the box.Even if you install Viu, the Viu player also cannot play any video because Viu sets a lot of restrictions.
But I heard from some people some android box will work for Viu.
