Android TV Box
gregory_choo
Greg
Have u tried the tvbanywhere TV app? I installed and it ask me to pair but the website keep giving me error when I key in the 6 digit code which is displayed on my tv
The latest plus version can be installed on mibox and you can log in from there, dont have to pair
yuto_kagui
Please advice
hi there, beginner at TV box here. Would like to seek advice on these 2 TV boxes I found online.
https://www.lazada.sg/products/prei...FDHvPAFdjsrjwouiHIYn-Bb75nbDvIUb3lLHMv_6tSygo
https://www.lazada.sg/products/tx3-...-QTOapee3-XeIRB5_epjZNaEmFper--28BvZY1rKoWUw8
Are they worth buying? My requirements is to have something that replaces my Starhub TV. It's for my mum.
Also, I notice their live tv channels do not require subscriptions. Does that mean their connections will be unstable? If paying for live channels help, may I know how I can go about to do it myself?
Thank you.
gregory_choo
Thank you.
no.
These are cheap boxes with free apps and sold at premium price. You should be able to find similar boxes at $30-$60 cheaper.
Sambuca78
hmmm just wondering, i just bought the TX5 max box from shopee and applied the 5 dollars off coupon and used a DBS card to pay. Somehow the total shows the 5 dollars off but not the DBS card discount. Why huh?
Update:
Anyway just called them and they say before i didn't buy from shopee mall, there is no 5 dollars off for dbs card.
Oh... Paisay that i provided sala information. :(
anyone has any good apps to recommend for Korean drama?
Viu is the major streaming platform for Korean entertainment. You can try Viu or Viu for Tablet version from Google Play Store to see which one works better for you.
Both free and paid option are available.
meleeme
Hi looking for android app that has wwe channels vods and live streaming. Any app that can be support this?
I always want to try out Super Low End Box like the old H3 CPU based box which will struggle with 4K but should be good for 1080p.
I use Armbian Linux with my Orange Pi PC (H3 CPU, 1GB RAM) it works fine. However no luck with good Android image. Previously I tried H3Droid but it seems to be the old Android 4.4.
Then from an Orange Pi Facebook page, someone recommended the Sunvell R69 H3 rom running Android 7.1.2 for the Orange Pi PC and it seem to work perfectly (Google Play Market , Dangbei Market, Kodi 18, YouTube, etc).
Instruction:
Burns with phoenix card in startup mode. https://drive.google.com/file/d/1ZjO47X3H8XHLt3ehzhYI01Ip7ulJLgKE/view
For reference quite some old box like UBox Gen 2 and Beelink X2 are using H3 CPU.
I wanted to buy Sunvell R69 2GB/16GB H3 Version last year from Taobao but the shop delivered the wrong RK3229 version to me. RK3229 is of course more powerful than H3.
I use Ethernet connection and USB wireless Keyboard/Mouse with this Orange Pi PC experiment.
I am not saying this is a good board to use though since Amlogic S905 Family is much better. But it is good to see old Low end Box can still be useful with right apps for your needs.
gregory_choo
Then from an Orange Pi Facebook page, someone recommended the Sunvell R69 H3 rom running Android 7.1.2 for the Orange Pi PC and it seem to work perfectly.
Instruction:
H3 is used on ubox3 and ubox4. As long as you disable playstore and play services, it performs quite well.
H3 supports hardware decoding for most of the china apps, better than AML and RK chips.
For Ubox3, although it is claimed as a 4k box, it is using a 720p kernel, most likely the FHD&4k are upscaled from 720p. You can see the info from kodi's system info page.
I think UBox 3 and 4 use a slightly better CPU than H3, they use H5.
Edit : you are right and I am wrong. UBox 3 and 4 are using H3, 1GB RAM, with Android 5.1.
http://www.unblocktech.com/en/ubox4/parameter
UPro and UPro 2 use H6, which is much more powerful but then they still keep using 1GB RAM.
Yes Kodi only works with 720p for this H3 board. YouTube TV version seems to be fine with 1080p.
I will check out more later to see whether it makes a big difference to disable Google Play Store and Play Services.
I have another junk box based on S905L and with 1GB RAM but that is the same class CPU as S905X so it is really more powerful than H3. That China Mobile OTT Box also has fast dual band WiFi. The issue there is the old Android 4.4 and no Google Play Store, which makes it pretty responsive but only good for Chinese Entertainment.
mankind66
Mi store selling mi box s
jonatan1312
(Ask) Looking for a recommended Android TV Box
Dear all,
I'm looking to buy an android TV box to replace my starhub cable TV which I'll terminate soon.
May I know what is the good brand of Android TV box with the budget max $70 (slightly higher than $70 is ok).
I saw xiaomi mi box S sold in Shopee and Lazada from China. Will it work in SG?
Any other brand beside xiaomi which I should consider to buy?
Can we watch VVDrama channel from android tv box? My wife is a fan of this channel at starhub so I try to find an app for her to continue the VVDrama TV series.
Thanks in advance for your reply.
Dear all,
Mi Box S is a good buy. Whether it can replace your StarHub TV is another story, all depends what you want and how much you want to pay for the alternative solutions.
Read Page 94 for more options but Mi Box S should be the first choice for boxes.
Also read here on how some of the people cut StarHub. The main reason a few of them are able to cut StarHub is because of TVBAnywhere+ is now available on Android TV OS device like Mi Box S. Then there are alternative streaming solutions like SingTel Cast, StarHub Go, Netflix, HBO Go, Amazon Prime Video, Fox+, Hooq, Viu, etc.
https://forums.hardwarezone.com.sg/...ed-cable-tv-fibre-tv-starhub-5792737-150.html
angy
@xiaofan,
Do you think this will come out soon or just hot air?
http://ugoos.net/blog/AM6_pre-release
I have an old Minix U8 and it had serve me very well. I just have itchy fingers and wanting to try the latest box out there.
Last, do you know off any Andriod TV box that can record playing on the app? Say i am watching football on an app. Is there such a app/TV box that can record that football match?
@xiaofan,
Amlogic S922X hexa-core (4*A73 + 2*A53) boxes are on the way. First one is Beelink GT1-K (GT1-King). S922X is Amlogic Solution to compete with RK3399 hexa-core (2*A72+4*A53) CPU.
I do not think the S922X boxes will be popular because the cost will be high. RK3399 boxes are usually above S$120 with 4GB/32GB or 4GB/64GB configurations and they do not offer real benefits for the main use case of streaming application for Android TV boxes. A few reviewers like RK3399 boxes for the smoothness of the operation and for large Kodi build or better gaming. That would apply to S922X boxes.
Edit to add:
There are boxes which claim can record on the fly like the generic A95X S905X2 box which has a HDD caddy. But in reality it is using screen recording. I believe there are apps which can do this from Google Play Store but I have not tried it. Performance will not be good. You can try them.
Reviewers typically use TV Capture Card on the computer.
If you need to record, potential solution is to use TV capture card on PC/Mac.
On Android TV Box side, Zidoo boxes can be an alternative— they have HDMI IN. So you can use your Minix U8 Box as the source and then use the Zidoo Box to record. Lowest end is Zidoo X9S.
angy
thanks for the reply. I still remember when U8 first came out, I paid a "bomb" for it. But, it is a very stable box. No problems at all.
By the way, any idea about my last request about recording?
S922X Box should be good if you are willing to pay. Just wait for a while to see how are the reviews. Beelink is probably a better brand than Ugoos.
Reviews are on the way.
https://androidpctv.com/amlogic-s922x-benchmark/
https://androidpctv.com/beelink-gt1-king-amlogic-s922x/
Please refer to my edited answer above for the recording questions.
