Mine is 240mm AIO - Dreamcore Nebula 240 AIO as my set is from Dreamcore hahaFor vertical mounting, what cpu cooler are you using?
lazy to self assemble nowadays
Posted from PCWX using SM-F916B
nice, with your gaming x trio in vertical mount, did you still manage to squeeze in 120mm fans at the top? my TUF card just barely clear the fan.
Now experimenting with TG panel with vertical GPU & AIO, but i rotate the case on its side to use it like a tower. Case fan & AIO pump set to silent curve preference, fans under load nv go more than <1300rpm
Cpu
idle 39-45
Load 67-73
Gpu
normal desktop usage 41-47
Gaming Load 78-85
When Using Aircon, temps on avg can be about 5 degrees lower. Cpu under load doesn’t go above 67, and gpu about 75-82
This Orientation reminds me of the NZXT H1. Why dun just buy that?
Only manage to squeeze in 1 at the top on the left.
Right side i see the power pins would make it too tight.
closer pic in operation
After adding 2X 120mm noctua fans at the bottom of the case and a 92mm exhaust, cpu and gpu temp dropped summore.
Now cpu on same load 57-59 instead of 60-62 and gpu 58c instead of 65c.
Abit ugly but works well lol
Ps how the heck you guys put pictures? I see a broken image
Temps while gaming:
CPU - 60-65 degrees
GPU - 60-70 degrees
Idle - both around 40 degrees
Using Scythe Mugen 5 Rev B for CPU cooler
Replaced the free fans (from case & cpu cooler) with Sirius Pure ASP120s
CPU cooler - 1 intake fan
Case - top 2 exhaust fans
Ignore the cable mess, this was taken during initial testing![]()
