- Sep 16, 2018
let me try to clarify..
this is how my connection is
TP->ONR
->STB1
->STB2
->Askey (living room)->wired backhaul->Askey (bedroom)->desktop PC
->smart TV
what brand and model wifi mesh should i switch to?
Your connection looks correct. As you have Ethernet connection and you are using ONR, cheap dual band mesh should work.
Depending on your budget, you can consider the following.
TP-Link Deco M5 (AC1300), cheap and pretty good, with local waranty
Huawei AX3 Pro x 2 (AX3000), cheap but no local waranty, Chinese web GUI
Asus RT-AX58U (AX3000) or TUF AX3000 + RT-AX56U (AX1800), AIMesh
You can also consider better brand like Asus Zenwifi, Netgear Orbi and Linksys Velop if you have higher budget. I tend to think Netgear Orbi is the best among the three. But then the higher end triband is not cheap and not really that worth it now that you have Ethernet connection.
