RSKeisuke
- Aug 26, 2000
In your case, actually you do not need to use the Askey at all as your SingTel STB boxes are directly connected to the ONR. For example you can sell the Askey units and replace them with cheaper Deco M5 or Huawei AX3.
Still you may want to double check if your connection between Askey01 to Askey02 is good. Supposedly you are using Ethernet backhaul but it might be still using wireless backhaul. What is the speedtest results from your PC?
Ran a few time before... All around 900+ Mbps both down and up
Posted from PCWX using Pixel 4 XL
