anyone using simba senior plan?
yuzu28
IMHO.
Not yet. I just got not long, so far see MY only.
But local speed at my usual locations is better than Simba.
However, I use Simba because the other telcos low to none reception - underground carpark. :ROFLMAO:
MY roaming ok bo? My simba really cmi
Ye_Rongtian
Speed at my house is 0.xx mbps. Speed outside is x.xx to xx.xx mbps. Just walking to the lift lobby can get x.xx mbps while at my own flat in living room is only 0.xx mbps.
PiKa
IMHO. When my Heya.SG cannot, my Simba also cannot. 🤣
So I am not sure why got people say Simba ok in MY. Maybe are my locations.
still quite ok le, the reception:
City Sq, KSL, Southkey, Toppen, Mount Austin, Ipoh (some part not ok), KL (some part not ok).
keenklee
IMHO.
I was in KL. I think is because some parts really a lot of people and cars.
I never really tested in JB.
tanahgu
simba 4g at my home also 0.xx mbps
if enable 5g, will be higher
The_Davis
High Honorary Member
Deluxe Member
You’re speaking the truth mah.
I started wif TPG when it was on free trial.
Their performance & reliability from then till now can only be described as äø€č½åƒäøˆ - just getting worse & worse. šŸ˜’ Phone shows 4G signal but the network experience ish macam rike 3G.
I try use the 4g data only plan on 5g mobile router.
Really shake head :(
