Apple Battery Replacement Program 2019 ($69 and $99)
reddevil0728
Replace my iPhone 8 battery w 3rd party last May. Its draining really fast still.
Will Apple still allow me to do the $99 replacement? And also do you guys think it will help?
They should be willing so long as there are major parts missing.
I think I learned my lesson 6 years ago when I replace my iphone5s battery at 3rd party shop. After replacement it's working for the next 3 months, after that everything went downhill, then I opened up the iphone, I noticed some screw missing, I think the cable cover also missing, they did a lousy job. after that, I only go to the Apple store or A-lab.
in the past when the battery replacement it is expensive, might make sense to go 3rd party. but after their batterygate saga, it is much cheaper now. may not make sense to go 3rd party. the difference is not too big.
Yep. made an appointment online @ Apple Orchard for later. Try my luck.
Big question is .. will i benefit more using original Apple battery .... ?
quality wise yes.
Kinda regret going 3rd party previously. Apple was ok to provide battery replacement (despite its a 3rd party existing), but during the 30min service, they alerted me that they cannot proceed as there was no battery tab. It was missing, and they would not proceed due to risk of damaging the phone.
Alas… lesson learnt.
But at least they confirm will replace as long as previous installation was done properly.
yep
grynove
replaced my ip8+ battery at jewel apple store. 1hour later say my iphone dead after battery replacement. even tho they give me new unit iphone 8+ still dulan need to restore all my stuff.
reddevil0728
Imagine 3rd party.
wonder if dead what will happen
szeli
wow gave u new unit, that's nice.
reddevil0728
I think that’s their standard protocol.
if you bring your unit to them for repair, after their repair doesn’t pass their diagnostic test, they provide you with a replacement unit. May not be new likely refurbished
armadilloshield
I think always a good idea to backup first before doing any servicing. murphy law always apply haha...
Actually Apple store staff will mention that you need to backup the data too, even though they will tell you that chance of losing data is low.
I changed the iPhone 6S 128GB battery in early 2019 and iPhone X 256GB battery in late 2021, in Apple Store Orchard Road. Experiences were both pretty good. The 6S is still alive even though I do not really use it. The X is still in active use by my wife even though we will most likely change it later this year.
BTW, if the diagnostic shows other problems other than the battery, the staff will usually offer recommendation as well. For example our iPhone 6S+ 128GB had the Touch ID problem when we wanted to change the battery along with the 6S in early 2019. The staff recommended us not to replace the battery as it might not worth it, and we listened to his advice.
crystalnox
Has anyone experienced going for the $115 Apple Watch out of warranty battery replacement? Do they swap a new one for you on the spot or do you have to come back another day?
tuntun
So you went to change at Apple center..They did not ask any questions due to replacement at 3rd party outside? How much did they charge you? My 8 plus also battery changed with outside shop and now started not lasting to use after 5 months. Thanks
galliano
No. They ok to do the battery change $75 even if its 3rd party inside existing. The only problem they face was the improper installation of the 3rd party battery. Let me share my DIY experience soon.
tuntun
Thank you...I will go there soon to replace my iPhone 8 plus battery....
galliano
Ok. i did a DIY battery swap tonight. Primarily cos Apple rejected me due to the improper installation of my existing battery (stupid 3rd party shop). Here to share my experience.
1. Took me 30mins to literally pry the damm 3d party battery. I actually scared myself, cos my tweezer punctured the corner of the existing lithium battery .. and it created a small flame. Lucky i put it out quickly,
The 3rd party shop DID not use the proper adhesive tabs (akin to those 3M pull & dislodge type). They simply used strong double side tape. So it was virtually impossible to take out the battery without slowly using a ruler to "lift" and scape the bottom of the battery.
2. After which the replacement was relatively simple.
Purchase the Baseus Battery For iPhone
(https://shopee.sg/Baseus-Battery-Fo...Phone-X-Xs-Max-Xr-7P-8P-i.68716077.4770828713)
It comes with everything required.
3. Only problem is i made this stupid stupid mistake.
Think i should have connected the battery 1st before i pasted the battery down.
Cable is bit too long. Could have avoided this by shifting the battery slightly to the other side.
So now i have this piece sticking out. Its quite sharp.
But i could close the phone back.
And it works.
Sigh .. mistakes made.
Biggest lesson learnt. Sent it back .. let Apple do it for $75.
Anyway, hope my feedback provides some valuable lessons in case anyone wants to DIY. Its quite easy really. Cept the messy part is removing the battery (IF its installed improperly)
armadilloshield
And it works.
Yeah, totally agreed, I ever tried DIY on my iphone 5 long time ago, change by apple for $75 less headache and 100% original battery haha...
s3856
Replace my iPad Pro 10.5 battery with 3rd party last Apr. But now totally gone, even I can charged to 100% but next day only 5% even don’t use.
Will Apple still allow to replace battery?
tuntun
Are you able to replace at Apple direct?
s3856
Still haven’t make appointment with Apple to service my iPad yet.
LIN_JOEL
And it works.
Suggest next time u let the battery run flat 1st before you proceed.
When u pry open those connector, beware that those parts with the "cushion foam" got connector parts hidden below.
If pry open wrongly with force will damage it and cause problems..
aucheukyan
my iphone 81%, should i replace now or just wait longer. Still enough for whole day usage
