Banking apps issue with iphone XS max ?
pohpohh
the posb digibank app now no more slide to view balance already... :(
iphone xs btw.
kashanai
Works for me, just remove and add again
Apart from the UOB and Citibank app issue, I also have a problem adding my UOB credit card to wallet. Did anyone experience it? Adding other cards are okay, but UOB one says invalid card (previously was working on old iPhone).
edit: Just realised other master cards are okay, AMEX fine too. This UOB one is Visa, I don't have other Visa card to test if it's Visa or UOB problem.
123kidy
there's an update for UOB app
problem seemed to be fixed
now left citibank app for Xs Max cannot work
Level42
I can’t enable Face ID in DBS digibank app. Anyone also encountering the same issue?
Under Settings/Personalisation change. For my case, the digital token didn’t work for me too. In the end, delete, re-install and re-setup, including deleting the old phone for which my digital token was previously setup.
I can’t enable the Face ID under Settings/Personalisation change, other than that all ok.
