Brake pads
Arsene_Wenger
Suspended
Hi,
Does anyone have any workshop to recommend that sell original brake pads for honda civic 1.6?
I wish to use back the same brand and type of brake pads.
The pads sold by kah currently for front at $190 and for rear at $170 exclude labour charge.
Another workshop riverview auto that i have found charged for front at $100 and for rear at $70 to $80 and labour charge between $40 to $50.
Are the prices provided by this workshop reasonable?
The work shop has mentioned that there are alot variants of the brake pads ( like quality wise ) on the market but as far as i can remember kah work shop has told me that there are only 1 type of brake pad for civic.
Are there something i need to be aware of? Thank you for your advice.
Capitalist
Just changed mine 2 weeks ago during servicing.
S$80 for a pair (front).
PM me if you wanna know which workshop (at Bukit Merah).
q w e r t ii
yes there are many aftermarket brake pads available but imo u dont need them because stock is usually good enough
Arsene_Wenger
Suspended
Yes. My stock pads r wearing out. Left ard 10 to 20% mre. Last me abt 5 yrs - 585k mileage.
Hence need to change nw. Will prefer to buy original one since pads n tyres r important components of safety.
q w e r t ii
either u buy from stockist, bring to workshop change
or buy direct from a workshop
the prices from kah motors are crazy
famasutika
Any idea how much it costs for a pair of front and back brake pad for Toyota Wish 1.8?
Capitalist
Like that meaning Brembos are lousy? Tyres such as CSC5, Michelin's PS3 are lousy - since they ain't stock? :s8:
only taxi clock this kind of mileage.
585,000 km over 5 years = more than 320 km per day!
Think engine chui liaoz lah! :s13:
Arsene_Wenger
Suspended
haha, of course cannot generalize based on my statements la..:s22: but then since i have used it, drove it and feel comfortable with it then will prefer to stick back to stock ma.:s12:
ok, right :D
Or you have any recommendations?;)
bolts
You can try Pek Tiong Auto at Yishun Industrial park A. Google for the number. Tell Mr Ang that you want only original Honda brake pads to be installed and ask him for quote. If you are happy with the quote, go down and see him.
For tyres, you don't need original Honda tyres. Any good branded tyre that matches your current tyre specs will be ok (Check the car manual for the right wheel specs) - look for something like 195/60/15 in the tyre section of the manual.
Expensive Quiet tyres - Turanza GR90, Yokohama Advan DB (Around $140 - $170)
Cheaper Quiet tyres - Turanza AR10, Yokohama Earth 1 (I think Around $95 - $120)
I have no experience with non-Japanese branded tyres. So, cannot comment. Currently on GR90s. These are much quieter and have better road grip than AR10.
henrylbh
Whether it's 585k or 58.5k for 5 years is unbelievable. Can't be so over-used or under-used.
My mileage is 122k for 4 years and only then agent workshop changed front brake pads for me.
henrylbh
That's cheap. More than 20 years ago, I diy and bought a pair of honda front brake pads already cost me $90, excluding brake oil.
tatsit
High Honorary Member
i'm using EBC green stuff for my brake pads, $220 for front pair
ZhuTou!
Ebc green got sound?
I saw many people using
Seems good
