matchy
High Honorary Member
- Feb 24, 2007
Ya. Drill hole, spray inCan put insulation in between.
loading definitely allow use of brick or hollow block walls. No issue at all.Just curious...
can, just need to plan in advanced and add bracing within the partition wall.My friend's 6yo BTO already using drywall
Cannot drill and mount things on it
don't anyway say cannot. HDB renovation is controlled at 1.2-1.5kN/sqm (cannot remember liao). Normal public buildings are usually done at 2.5kN/sqm (if my memory serves me well). At 1.2-1.5kN/sqm more than enough to use hollow block walls at strategic places add cement to support wall installation eg. TV. My agaration is probably use brick walls may not be an issue as well. Reno experts can prove me wrong since me no expert.Cannot. The building design cannot take the weight. These days, even condo also use drywall.
Aiya just check your floorplan la. The darker and bold colour is structured wall la. And others might be drywall.
The drywall does not give good protection against noise. But it's not so easy to kick la. More likely it will break your leg than you break the wall.
IMHO.Never hear of anyone’s flat have soggy walls. Mold yes especially toilet areas.
Actually only the top floor beams are thicker. Rest of the floors are same due to precast walls and modules.loading definitely allow use of brick or hollow block walls. No issue at all.
as a general rule of thumb for layman, non structural elements can be removed.
For experts, some structural elements can be tweaked/adjusted if you know what you are doing. Of course HDB will think otherwise.
The higher the floor, loading required on the structural elements will be less. Hence if one check the structural loading calculations from structural engineers, one will find some columns on top 2 floors can be smaller or removed.
IMHO.
You see those HDB flats that the exterior the paint colour like different. Those are likely to be soggy walls.
So the consideration is not for new HDB is whether having wall mounted furniture is a good thing.
IMHO.The drywall that HDB used is rated for minimum 25kg load at each anchor point. With sufficient anchor point , you can mount most stuffs.
I personally havent seen soggy wall. What are the issues of soggy wall? I would imagine any structural impact from soggy wall is covered by building warranty.
One is a wall.. the other like cardboard partition.What is the difference between dry wall and concrete walls ?
Drywall need to hack?Should be ok. Just need PE approval for hacking usually.
u got check the cost.
