[CASE] Phanteks Enthoo EVOLV ATX
souler87
yeah, the manual did indicate it a reset switch yet we don't have a reset switch connector.
I think for the front panel LED you need to connect a sata power to one of it wire label 12V for LED.
Update: Okay I just find out that the 'reset switch' is actually just a button to change the color for the power and front panel LED.
Corbell got bring in this?
http://www.phanteks.com/PH-LEDKT.html
White dawn
For mine it only have the power switch n the HDD led? Led is the one for the front panel? I'm was thinking how am I going to change to the red led included.
The internal black paint also easily scratch off so for those need to change the motherboard standoff do take note.
Ya. The case is not scratch proof. Plus when u opened it up, actually got some minor scratch mark but I lazy wan bring the whole case for exchange
Sent from Pillars of Creation using GAGT
@Corbell
Suspended
Hi guy,
Our technicians are checking and will revert soon. If got issue, we will settle nicely for you guys. Now worries. ;)
Bluegrass_Corbell
Suspended
we do not have this yet, maybe have to be with the next shipment
Vulpix
Moderator
Moderator
Thanks for bringing in the case, I gonna get the mATX one next week. :D
*adiBOY
Funny this is, the tempered glass Evolv ATX is not even listed on Phanteks website and we are the one of the first if not the first to get it.
clon22
Suspended
Just to update :
As mentioned by souler87 too.
There is only a power button.
The "reset" button is actually an LED indicator switch
which changes the LED colours :
One thing to take note : (mentioned on in the instructions too)
Remember to connect the "cpu fan connector to the mainboard "CPUfan1" header.
If you connect to other fan headers, the casing fans will not spin.
Apart from that, there rest is quite straight forward. :)
There's a whole bunch of accessories inside. @@
MicLimHS
Just to update :
I found the 12v connector.
Very nice indeed :)
holyark
any chances to bring in Enthoo Evolv ATX?
I don't really like the two sided tempered glass for the current ATX version.
Will sure take it if it's only 1 sided.
